Hey all,
I have had these bits from my r33 skyline for a while now sitting in a box in my shed, and was gonna hang onto it all to build a new project out of some of the pieces but i'm starting a new apprenticeship soon and wont be able to fund it so i may as well let it all go (doesnt help when the old mans whinging about his shed room!!)
So i have a few things up for grabs:
Brand new Garrett 35/40 with a polished AR .07 front comp, and .82 rear housing....was on the car for probably 1200kms and never got boosted past 15psi $1200
RB25DET Billet injector rail, sprayed black $100
Horsepowerinabox.com turbo beanie with "PROFLOW FABRICATIONS" stiched into it $150
XF throttle body with which im pretty sure is a new TPS on it $100
Custom made catch can to suit a rb25det R33 skyline ONLY (have pics of where it was located), but could be modifyed to suit any application $200 (may seperate fittings)
RB25DET Hi mount exhuast manafold with 38mm Ultragate....will seperate if required (one turbo housing stud is mising and one got molestered by the bloke taking it off....only just realised it when i took it out the box) $700 with gate or $450 without
45 Degree turbo mouth intake pipe (fits the housing on the 35/40 so can sell together with turbz or seperate) gave it a decent flutter off throttle $80
These things where on my car for about 1200kms and none of it really got the chance to be worked propely so everything is still like new and is just sitting at home doing nothing....may as well try get some coin for it all
I may be open to swaps, depends on what it is and if im of interest
Id prefer people to message or call my number...its 0415080029 and will answer any questions regarding any of the stuff!! If i dont answer i will call back
I have receipts for all this gear and can supply for proof of purchase if needed
Serious buyers only....No time wasters!!
Located in S.E. of melbourne.... so local pick up only...not interested in shipping
Cheers
P.S: stuff is advertised elsewhere and i retain the right to withdraw any product from sale on here
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
