http://www.skylinesaustralia.com/forums/at...achmentid=11528
2540 rated at aprox 340ps at 1bar i think
2835 rated at aprox 360ps at 1bar
I think steve said the hks turbs are all measured at 1 bar. So u could wind more boost into the car easily. Also search the forums, think someone a while ago had a huge post about his 250rwkw r32 with rb20.
cya
https://www.sau.com.au/forums/topic/36255-2532/page/2/#findComment-725888
  • Replies 72
theres a few shops around here that sell good second hand turbos. Speak to someone like D1garage. they will give u good advice on what is best for u. then if u want they can source a turbo for u. other then that, look on ebay, these forums, and other shops in adelaide, like hikari performance, city jap parts have cheap turbos all the time.
https://www.sau.com.au/forums/topic/36255-2532/page/2/#findComment-725955
I have seen a 2530 on RB20 make 230 at 1.2bar with 8200rpm redline. It was James (D1 Garage) cefiro, and it went bloody hard - you are looking at an easy 12 second car with that sort of power. Jut be aware that your gearbox may not like it too much, so make sure your tyres arent too sticky:)
With a 2530 you will get a big fat midrange and will come on boost early (ish). 2835 on grepins car is making 274 at 1.3bar, but will have alot more lag than a 2530.
It depends on your driving style. If you dont mind a bit of lag, go a 2835 (or even a T518Z) - if you want something with more down low, go a 2530. anther one to consider is the 2535, but once again it will have more lag than a 2530.
Having 8.5:1 CR, you can run 1.5+bar all day with a good tune and be very safe - so no probs there.
D1 Garage sell a new HKS2530 with ALL the bits (oil line fittings, water line fitting, snout for outlet, actuator (I think), etc, etc) for $3K. Second hand you may be able to save around 1K or a bit more, but for peace of mind, and so you dont end up having to buy more and more bits to make it fit - the new kit is pretty good value for money IMHO.
Give them a call, or better still drop in and see them - James lived in Japan for 4 years, has heaps of connections over there, has seen alot of different setups, and I am sure he will be able to help find the right turbo for what you are after. He has saved me a fortune, as I originally met him looking for an RB25DE head for a 3L conversion. After chatting to me, he talked me out of it, as he assured me I didnt need to go that path for what I was after. Tell 'em I sent you too, more discounts for me later:p.
https://www.sau.com.au/forums/topic/36255-2532/page/2/#findComment-726095
thanx enrico and steve
you have both been a huge help
but seeing my car is still pretty much stock i guess i should get a few other things first
like fmic, oil catch and cooler, boost gauge and controller, dump pipe. you know
all the basic stuff i was also thinking maby one of those sub zero plenums
and i guess if the rb20 blows in the feuture i can always do the
rb25 thing then
thanx again guys and i might see yas on the next cruse :boobies2:
https://www.sau.com.au/forums/topic/36255-2532/page/2/#findComment-727558
i went into D1 garage and they had a greddy boost gauge (second hand) for $120. also a mate of mine bought the same gauge (same model gauge not the actual one) off them a few months before for $120. So i went back to buy it for $120 and they jacked up the price to $150 and wouldnt budge (yes it is the exact same one), even know the had it on the net still saying $120. i had $150 but thats not the point so i didnt buy it, this sh!ts me abit.
https://www.sau.com.au/forums/topic/36255-2532/page/2/#findComment-751597
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
