Hey guys, i am wanting to get rid of my beloved r30, as i have bought an r34 project
\the car is complete except for the l24 motor and box
parts are as follows:
r200 disc brake rear end( prefer to sell complete)with 4:375-1 centre $400
Koni 90/10 shocks for the front with firm springs and stiff Koni shocks and firm springs for the rear $150
custom made 297mm? slotted front discs $250
with lower control arms/hubs etc
Early style dr30 rear lights in good condition ( very rare) $250
also have brand new in box late dr30 rear lights, never been touched and the box opened for inspection cost me an arm and a leg, so they wont be cheap. $500
all doors are complete as is boot and bonnet in good nick $50 each
front guards are good, $30 each
front and rear bumper bars $40 each( rear has 4 speed holes? but otherwise good)
front grill $20
1 nismo genuine bottom spoiler for dr30 (plastic)
maybe the only one in australia and super rare. realistic offers only
pics will be up over the next couple of days and can be sent to phones as needed.
postage to be paid for by the buyer, and free delivery within adelaide.( except for the rear cradle and bonnet, trailer hire needed for those)
the shell of the car is in great cond,i can cut panels out if needed
but maybe no postage for those.
also there is an electric sunroof but has been siliconed shut.
1 brand new alternator for l24 $50
interior has good rear seats in grey velour $50
front seats are from a hr31 in black and grey$150
centre console from dr30 $20 and $10 for the stock one
dash pad in good nick( grey) $50
1 dr30 dash and 1 mr30 dash, both pretty much the same,
dr30 has lower k's both have factory boost gauge. $50 each
2 lots of headlights, 1light has rub marks on the lens but could be polished out, $ 60 for the good set an $40 for the other
1 brand new clutch cylinder $40
brake booster and or master cylinder $20
anything else needed let me know
cheers, troy 0420 734 794
Edited by rb20-into-mr30=
https://www.sau.com.au/forums/topic/362792-wrecking-mr30-skyline-1983/
body with doors and interior parts scrapped and the diff and rear cradle went with it :(
whats left is: front struts (koni) with discs, they have cusco adj camber tops!! $250
rear bumper $40
front nismo spoiler $200
dr30 dash $40
dr30 tail lights x 4 $200 and $500
mr30 head lights x 4 $20 each
1 grille $20
1 bonnet $50
rear bumper $40
dr30 dash $40
1 grille $20
1 bonnet $50
bump!!!
Did you seriously send a long nose r200 4.375 diff with half shafts and disc brakes to the scrapyard?
yeah i know, but i ran out of time, had no man power to help and had to have space. $1000 down the drain but i was left with no choice
there was no interest until it was too late, i advertised for 2 weeks before my deadline.:spank:
quick update, front spoiler is the standard dr30 plastic type,not nismo as advertised.
still hard to come across though.:thumbsup:
located in warradale, adelaide
If anyone or yourself is interested i have a complete FJ20 engine and box out of a DR30 rebuilt with forged pistons by stewart wilkins motorsport custom fuel rail with bosch 750cc injectors with msd ignition and autronic SMC ecu tuned ready to bolt in and start
If it interests you pm me!
Would be a great conversion for a R30 skyline
Made 260hp at back tyres on 14psi never run more only 40k since engine was rebuilt untill the car slipped off the road into a tree (driver error on wet road)
  • 3 weeks later...
post-39514-0-60557700-1309050025_thumb.jpg <BR>early dr30 lights<BR> <BR>post-39514-0-17857800-1309050039_thumb.jpg <BR>Late dr30 lights BRAND NEW IN BOX!! L&R
bump!! I'll consider giving away the rear bumper and bonnet!
still have headlights and taillights!!!
  • 1 month later...
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
