hey guys,
my car is a manual S2 (narrower track in the rear).
i'm looking at ordering new rims and am tossing up between
19x9.5 (+22) all round
or
19x8.5 (+22) front, 19X9.5 (+22) rear (wider in the rear to compensate for the narrower track).
can anyone foresee any probs? tyres front and rear will be 235/35/19 (as i have them already). will rolling diamater be affected much from the extra stretch on the 9.5 rears over the 8.5 fronts?
https://www.sau.com.au/forums/topic/362910-wheel-fitment-for-rs4-s/
hey guys,
or
I run 19x9.5 +12 all round
The rears are flush at 320mm ride height and 245/35/19 tyres are a bit stretched. The rims are wider than the tyre, so the cloest thing to the shocks. No rear guard rolling needed on my car. Clears by 3-4mm
The +22 wheels you are looking at will run very close to rear shocks being 10mm further in than my car
You may need to check this before you fit the tyres
The fronts should sit pretty flush. As I have the R34 front, the guards a approx 25-30mm wider than stagea ones.
so darrin, perhaps a 10mm slip on spacer for the rear and everything will be ace?
10mm worst case. You may need to fit longer wheels studs, so more cost
You maybe ok without one or maybe just a 5mm
Also depends on what brand of shock as the diameter can vary. I have Bilstiens in mine
auto series1 wont help as it has wider rear track. i have 18x8 with a 34+, they sit in abit, standard kind of offset. the front is about 10mm of perfect flush and the rear is about 20-25mm but its hard to judge with 2'45 degrees of camber in the rear.
i rekon your second option is good but you need a lower offset in the rear personally, fella i got my coilovers off has a 15mm bolt on spacer on the rear of his 260RS for 17x9s.
or buy you first option and throw a 10mm hubcentric spacer at the rear
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
