I am looking at rims and tyres for my R33, but the guys at Bob Jame tyres suggest that the tyre setup I want (which they recommend as well) of 235/45/17 on the front and 255/40/17 on the back requires 9 inch rims on the rears... this cuts down the rim choices HEAPS.
They say the 255 will fit on an 8 inch rim, but is 'pinched' and does not sit well so reduces my traction.
The problem is 17 * 8 rims are everywhere and cheap (relatively), 17 * 9 are impossible to get and choice is limited... the only rim I can find is the Enkei RP01 which is fairly basic (I want deepdish dammit!!! :rolleyes: )
Any suggestions or comments? What have you guys gone for with rims?
https://www.sau.com.au/forums/topic/3637-rim-size-17-8-or-17-9/
Well, if you want 9" wide on the back you're going to have to spend alot of money dude, from what i've seen only expensive jap wheels are wider than 8" (well, stylish wheels anyway).
Perhaps look at some Advans, Rays Engineering wheels, or some Volks. All very very pricey wheels though. I think you should just go 8" wide rims, it's easier and cheaper.
Na , go the Jap drift look:cool:
I've got 235 's stretched onto the 10'' rears of my 300 zx TTDD ( thats Twin Turbo Drift Dog :( ) Cuts out any sidewall flex but no rim protection from kerbs.
Ken
Thanks for the info guys, I ended finding some cheap 9 inchers, so I have got my 17 * 8s on rht front and 17 * 9s on the rear, and a set of 235/45 and 255/40 P Zero Neros on order :(
I chose the Neros as apparently they give good ride quality and nose levels but still grip like crazy.. the rosso is even more refined, but it just looks boring in my opinion :)
HI Steve, i got the rims through Bob Jane Morley in Perth (Brett).
They are a Giemax import, and they have a few speccy looking rims that are in 17 * 9.
I would put a picture up, but I dont have any... only seen them in the showroom and ordered them (they were decent looking at cheap, and 9 inches wide so it was an easy choice :D )
I will have them end October (they have to ship them from Japan on the next container from Giemax) if you are still looking and would like to see them on the car.
Conrad
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
