Make: Nissan
Model: Skyline, R34 GTT
Milage: 155,000 kms
Transmission: 5 speed manual
Colour: Silver
Registration: Vic 03/12
Price: $22,000, will swap for car of interest (s13, s15, fd rx7)
Contact: 0431320142 or PM or [email protected]
Basic Specs
1998, R34 GTT
Platinum Silver
Nismo Sports Front Bar
Genuine East Bear Rear Bar
Genuine East Bear side skirts
Fibreglass nose piece
Fibreglass Eyelids
Nismo Smoked Indicator lenses
18" Koya RG TEK Wheels, 18x8.5 18x9.5
Tinted Windows
Interior
JVC DVD Player
Soundstream Front Splits
Soundstream Rear 6 inch co-axes
Standard Seats
Shadow Turbo Timer
Nismo Solid Shifter
Nismo Leather Shifter
Three gauge pod modified to fit three aftermarket guages, Boost, Oil Temp, Water Temp
Engine
New Engine with Great Compression
260 rwkws
Stanard internals
Nismo 480cc injectors
HKS Front Mount Kit
GCG High Flow
BATMBL Split front dump
Race Pace Super High Flow Cat
3" Kakimotto Exhaust
Meridian Motorsports Oil Cooler Kil
Splitfire Coil Packs
PowerFC and hand controller
Oil cooler kit
Large Alloy Radiator
Walbro fuel pump
4 gauge fuel pump wiring with relay in boot
Malpassi Fuel Regulator
Nismo Panel Filter in Stock Air Box
Silicone inlet piping and Silicone radiator piping
Drivetrain and Suspension
Bilstein Adjustable Coilovers
Whiteline Front and Rear Sway bars, adjustable both ends
Whiteline Rear Camber Kit
Whiteline Sub Frame Locking Kit
Whiteline Front Camber Kit
Whiteline Front Offset Castor Rod Bushes
Hicas Locking Bar
OS Giken Super Single Clutch
Braided Clutch Line, ADR Compliant
Lightweight flywheel
Kaaz 1.5 Way LSD
Brakes
DBA4000 Slotted Rotors Front and Rear
Project Mu Super Street Pads Front and Rear
ADR Compliant Braided lines
Cusco Master Cylinder brace
URAS Drift hand brake shoes
This 34 is in great condition, is reliably fast, handles, stops, and looks great! I've not owned this car for long and it's the first skyline i've owned. Having previously owned a few rx's and an s13, which i absolutely loved, when it came time to buy a nice car again i initially had my mind set on an s15. Once i started looking around i soon realised that for the same price as an s15 i could have myself a much stronger R34 with plenty of mods already installed. The problem is, i now realise that the skyline is not actually what i want out of a car at the moment... ah hum (a bit of privacy here please)... "Skyline. Look, we've had some great times during the brief time we've been together. But this is just not gonna last. You're great... It's not you... it's me (sigh)".
So... who want's to take advantage of this car on the rebound?
When i get my act together i'll try and take some pics of her, but until then i'll post some ones from a few years ago (previous owner). The paint now has some small chips, etc (nothing really noticeable - these were taken after fresh respray), The wheels in these pictures are slightly different (my ones look much nicer), and also i've removed the rear spoiler (tape over holes - can re-install if desired). Oh, it doesn't have the red S on the grille.
https://www.sau.com.au/forums/topic/363710-r34-gtt-260rwkws/
Just had a read over the ad and thought i should clarify... there's not really any noticeable chips in the paintwork, its just that the above two photos were taken a few years ago and just after a respray, so the finish now is probably not quite as good as this. For now I'll chuck up a couple of crappy photos i took today with my phone, but I'll get my act together soon and take some with a good camera and after a wash.
O.M.G
It's my Baby!!!!
Tell me how you came accross my car and how you bought it and why it hasn't got the Buddy Club PII rims on it!!!
Intersted to know all about it.
I'm pretty keen on getting an s15 at the moment. There are few i'm keen on on carsales which are below $20k so at this stage i'd probably be happy to take whatever it will cost to get me an s15. I do change my mind quite a bit so if you want to pick this up cheap, get in before i decide i'm after something more expensive.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
