Ok,
So have 2 pieces of damage to the rear bumper seen here:
post-1308-0-38305900-1305011897_thumb.jpg and post-1308-0-76817900-1305011937_thumb.jpg
I have then used some 80 grit wet sand paper to file it back as per here:
post-1308-0-54777500-1305012021_thumb.jpg and post-1308-0-38840800-1305012050_thumb.jpg
What would the ideal method to repair this. Was going to use some fibreglass reinforced filler over it and sand back. Then was going to use some primer/filler spray can to smooth it over and sand back. Then I was going to do basecoat with acrylic gloss black then acrylic clear coat.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
