come on guys be nice he is obvisouly new to the country and needs friends its worse than what it would have been like changing schools
im joel anyway love RS
thanks ,, i have been here 2years,study here and i love cars. i own a 08 370 gt. i love to make local friends. so.....
looking for friends in perth>love cars.
Hi mate, welcome to SAU.
My name is Victor and owns a 350GT (V35) coupe. I think I've seen your car sometimes around Curtin (My brother studies at Curtin and my wife works near Curtin).
There's a V-series event coming up next weekends. (http://www.skylinesaustralia.com/forums/topic/360651-wa-v-series-owners-meet-and-greet-no2/). Come along and meet other V-series owners. :)
