1993 Nissan Skyline R33 GTST Coupe
Rego till March 2012
Everything on the car is fully engineered
MODIFICATIONS:
Resprayed in custom blue with powdered blue pearl
400C Grill Custom Front Bar
400C Rear Bar
Custom Side Skirts
Bomex Rear Wing
Tien Coil Overs
19 inch Wheels - nearly new tyres
35/40 Ball Bearing Turbo
Tiel External Wastegate
Custom Manifold & Dump pipe
750cc Injectors
Custom Fuel Rail
Custom Fuel Pump Regulator
Upgraded Fuel Pump
Billet Throttle Body
Custom Engine Cover
Custom Plenum
Custom Heat Shield
Stainless Catch Can
Custom Stainless Tuned Exhaust
Blitz Intercooler
Blitz Radiator
BOV
Spitfire Coil Packs
All Braided Lines, Earls & Speedflow fittings
Chrome Trims Throughout the Engine Bay
Custom Leather Interior
Custom Painted Dash
Black Jag Carpet Custom
Leather Issotta Race Wheel
Issotta Hand Brake Cover
Issotta Gear Knob
GTR Dash
Auto Meter Boost Gauge
Auto Meter Oil Temp Gauge
Auto Meter Engine Temp Gauge
Auto Meter Stage 3 Shift Light
Chrome Trims throughout The Interior
Boost Controller
Turbo Timer
Alpine Head Unit
Alpine Speakers
Alpine Amp
Full Under Body Neon Set Up with Remote
Immobiliser & Alarm
This is an immaculate show car that has clearly has no expense spared on it. I'd hate to think what has been spend but I have kept all the receipts and documents from the past 10 years. Turns head where ever it goes hence the number plates! This car has been built with attention to detail.
This car has won numerous trophies at car shows including The Annual Skylines Australia Show N Shine where this car has won on several different occasions "Best R33" & "Best Engine Bay" and often is approached by various magazines to feature which has been declined to date.
Only driven occasionally on weekends and to events. Always garaged. Runs like a dream and everything works!
Has been serviced and maintained and would impress the most fastidious of buyers. Set up to run 300kw.
Lady Owner for the past 10 years.
Absolute Heartbreaking Sale!!!
NO TYRE KICKERS, JOY RIDERS OR DREAMERS!!!
More photos of request...
Included in the sale is all the spare parts I have left for the car....Body Kit, spare parts etc
$29,990.00
Serious enquires may be directed to Krystle on 0414 650 297 or via email mcinneskrystle at hotmail dot com
Optional extra to purchase is the Race Wheels off this car which are 3 Piece Works Wheels 17x8 fronts & 17x10 rear with 75% tread $1000.00
https://www.sau.com.au/forums/topic/363981-uloook-fully-engineered-r33-gtst/
Thread cleaned - Do not post unless you are genuinely interested in purchasing this car.
The next person who attempts to trash this sale with rubbish posts will enjoy a one week ban
  • 1 month later...
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
