r33 sr1 bonnet in primer SOLD PENDING PAYMENT
RB25det sump $30
R33 sr2 wing needs paint $30
GTR wing no end caps needs painting(plastic) $150
R33 Air Conditioning Condenser gtst 1994 $35
R33 gtst sr1 front wiper motor $30
R33 gtst sr1 rear wiper motor $35
R33 gtst sr1 climate control $35
R33 gtst fuse box and cover $20
R33 gtst sr1 bonnet hinge set $15
R33 gtst overflow and washer bottle $25 for both
R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET $50
RB25 R33 GTST SR1 CAS CAM ANGLE SENSOR AND BRACKET $45
R33 RB25 skyline power steering reservoir with lines $20
RB25det sr1 stock injectors all work fine but some have broken plasic ends but can replaced $20
R33 Air Conditioner Compressor with lines as seen in pic $50
RB25det sr1 aac valve $40
fiberglass vent (uncut vent) $50
rb25 turbo 45v2 has a blown seal $50
R33 gtst sr1 abs unit and bracket $60
Rb25det sr1 flywheel $40
R33 gtst coupe sr1 door handle's $30
R31 sr3 grill $10
R31 sr3 bits lot $15
R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25
R33 gtst light garnish $30
R33 centre interior light plus other? $25
R33 turbo oil drain pipe $10
rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $70
r33 horns $10
catco high flow cat 2.5inch 325mm long $50
apex rb25 front pipe 2.5inch has a few dings $60
Nismo muffler 2.75mm inlet with 4.5inch tip $100 plus rear section that suits r33 free with muffler
RB hard oil turbo line $25 (not sure if its rb20 or rb25)
RB hard water turbo line 1 $25 rb20 rb25?
RB turbo hard water line 2 $25 rb20 rb25?
R33 gtst window wiper set $ 15
R33 gtst sr1 passenger side electric window switch and loom $45
R33 gtst sr1 2door seat belts(not sure if its complete) $50
R33 gtst sr1 air con units that sit behind the dash $90
RB20 RB25 Coil Pack Mounting Brackets(might be some bolts missing) $20
pioneer reverse camera bought it 2 years ago for $100 from jb hifi but never used it. $25
vr v6 commodore sedan fuel sender and pump(pulled from running car but hade different plugs to myn) $40
R33 rb25det charcol canister $20
r33 boot latch with plug $20
R33 boot and fuel lever $15
R31 1989 oz spec bonnet latch and lever $15
R33 a/c receiver,drier sensor $30
rb25det fuel modulator with bracket$25
R33 gtst R/H drivers door glass $40
R33 gtst L/H drivers door glass $40
R33 front window $70
R33 rear window $70
R33 gtst front fenders rolled and liped $170 for both
R33 stereo brackets $20
R33 sr1 dash trim(needs a clean and paint) $40
pm me or sms 0435 888 239
Will post at buyers expense
Dave
  • Replies 116
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
R31 sr3 4door window wiper and headlight indicator switch stalk(in good working condition) $25
Dave
apex rb25 front pipe 2.5inch SOLD
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
Dave
R33 front window SOLD
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
r33 sr1 bonnet in primer$100 has a small dent(can send pics)
Dave
Hey mate,
Chasing a few parts, not many are listed, if any.
Both left and right rear quarter glass
S1 Air Compressor
S1 Air Condensor
HICAS ECU (located under parcel shelf in the boot)
Also Power steering rack sensor, not sure if it is on a S2, but is on a S1 (Located on drivers side of motor on a line that goes into the power steering rack)
Let me know what you have and the cost, and also the postage to Perth.
Thanks
Morgan
RB25 R33 GTST SR1 CAS SOLD PENDING PAYMENT
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
Dave
rb25 turbo 45v2 SOLD PENDING PAYMENT
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics is what you get. Only selling as im going custom dash for track car.
$70
items are a bit dusty as they have been sitting in my shed
Dave
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics (page 4) is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $70
R33 gtst false rear wall $20
Dave
R33 gtst overflow and washer bottle SOLD PENDING PAYMENT
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
R33 gtst sr1 coupe rear quarter trims LEFT & RIGHT they just need a clean but in good con $50 can get more pics if needed
Dave
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics (page 4) is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $50
Dave
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
RB25det stock dump on black vht $20
Dave
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
Dave
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
I have r33 interiour parts, pm for what you after
Dave
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
Dave
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
Dave
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $50
R33 gtst rear bar with gtr pods both will need repair $50
r33 gtst sr1 power window motor regulator LHS $80
r33 gtst sr1 power window motor regulator RHS $80
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
R33 gtst fuse box and cover SOLD PENDING PAYMENT
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
    • The fact that US/JDM plates actually fit the skyline bumpers properly is a big, big thing for me as they are the correct dimensions. Annoyingly you can't opt for a normal plate (or plate combination) in that size. You have to make up your own one, and at that point you'd still know it wasn't randomly assigned.
    • Well, really, that's any ECU, because it's not so much the ECU that the tuner connects to, but a laptop that's connected to the ECU. You have to have the tuning software installed locally. The "remote" part is essentially just remote desktop (RDP) or VNC type access. Nevertheless, if you're looking to upgrade, then you're immediately in the Haltech/Link territory, both of which can be done by any number of competent tuners here in Oz. But without a dyno, you'll definitely also need a wideband O2 sensor fitted, and you'll probably be relying on "auto" tuning a bit, where you drive it around under various loads and then apply the corrections that the ECU learns (basically applying the fuel trims that the ECU has to do to correct the mixtures). Tuning the timing is a little harder. It can be difficult to trust the old OEM knock sensors on RBs, so it is definitely best to have someone who knows what they're listening for, with knock ears (a piezo microphone connected to the engine, and and little amp and headphones so the listener can hear the angry men with hammers who live in the engine). That is more difficult to do remotely, and I suspect the only sane way is to be quite conservative on timing. But that's OK. You're probably waaaaay better off with conservative timing where you are. What is the fuel situation? 98RON available? Or low grade jungle juice?
    • I see your point, I didn't think too deep into it, was purely focused on the price. There's no bad blood between myself and GSM, they acknowledged the price was cheaper else where and at the time couldn't match it.
