Hey Guys,
I have been around these forums for ages, but never joined so sorry about my first post being so big. I have a 96 gts-t with a rb26 single turbo conversion. The problem is that it is not making the power that I think it should for the money I have spent. Also I have a problem with boost control, my car seems to run stupid boost and make no power. There are talks that the wastegate is to small. The car has made 330rwhp at 22 psi with the following (see below). The car made 210 rwkw at 8pound at 5000 when the motor was being run in so I was expecting big things but at the moment am very disappointed. Am I expecting to much??? Can you see a problem with the build. What would you guys expect the car to make. RNZ11s I raced you when you had the 30/40 setup you might remember my car???
Rb26
Garret 30/40 700hp ball bearing turbo
Port and polish – JHH
Cam gears
Boshe 044
Sard 700cc injectors
Wisco forged pistons – Teflon coated
Shot peened and linished rods arp bolts
HKS Intercooler all piping hpc coated
Turbomsmart pro gate 42 m
Turbosmart super sonic valve
Standard plenum
Halteck ek6
Boost control is just a t-piece.
Thanks for you help!!!
  • Replies 61
ur wastegate seems fine
but things to do would be
1. get a better boost controller or even wastegate controller
2. get a decent tune
with these to things - mainly the 2nd one u should c it close to 300rwkw easy
It might help if you could post a dyno readout. I'm no real expert with your particular set up but an RB26 with those mods...wow! I'd be expecting alot more too. Just wondering about the ECU & tune?? Does it run MAP or AFM's? Maybe this calls for Doughboy or SydneyKid....ring ring, brrrr, ring ring :rofl:
What the......................?
Clearly you have spent buckets on a tough rebuild so how could you possibly overlook the boost controller?
1. Get a REAL boost controller
2. Get another tuner.
The problems is I am sick of spending money to recieve the results I am getting. My thinking is spend 700 bucks to find out that it is not a boost problem, does that make sense. So many people have had a look and don't know what is going on. Getting over it.
As a guide, My GTR made 360rwhp or 270rwkw with Stock Motor, Apexi PFC, Cam Gears, Boost @ 15psi, & exhaust. Running stock fuel pump...etc etc wish I could help, love to see your end result sounds like an animal.
Ditto - 33GTR, same mods minus the PFC and same power
help: You need a good tuner
Hmm, seems wierd. I would be looking at your exhaust side, as already mentioned. If you are winding more boost in, with little return, it sounds like back pressure to me, or the turbo is well out of its efficiency range. If its a 700hp turbo, I think I would be correct in assuming the turbine AR is reasonably large, so I doubt any restriction is there.
try dropping the exhaust and take the car for a quick squirt (or better still put it on the dyno) - takes only a few minutes to drop. You do run a 'racing' cat dont you?
I had a nismo exhaust, that started choking the car at around 285rwkw, changed to a super dragger and made boost alot earlier, and got alot more top end - now making well over 300rwkw (on a 480hp turbo:) sorry just had to throw that one in:p)
take a good close look at your bov too - I have seen those turbosmart supersonics leak like a sieve, try putting you hand over the oulet whilst at idle. If it is leaking, you may still be making boost, but the car will be alot more lethargic off boost, and ramp slower onto boost instead of hitting hard.
Steve,
If "racing" is hollow then answer is yes. Then only reason I changed valves is cause apparently the apexi one I had was leaking to. Valves are annoying to say the least. I am not so much winding more boost in it just does what it wants, we got it a bit lower 18 pound and moved some of the solinoids for the haltec as my mechanic thought they may be fighting the standard ones for a signal. The car felt a little stronger with less boost. I will try and get a graph sent the guy who tuned the car is supposed to be looking after me cause I did some work for his so I will see what I can get. Thanks for telling me that my car makes crap power when I sought it out you will be the first to see the dyno graph :)
but that 700 you probably are well advised to spent IMO.
a good controller is probably one of the most important parts.
Aside from that... what AR is your Ex housing?
I find it pretty hard to believe this is caused by a boost controller
I was asking about your exhaust to get a gauge of what manifod / turbine housing you were using. Also with your ECU how much timing are you giving it throughout the maps? Is it pinging? A car isnt gonna make any power with 5 billion pound boost but **** all timing.
Need more details.
something doesn't seems right there could be anything from a blocked fuel filter to crappy mappings, Things like these take time especially in a conversion when all things are removed and the refitted in best possible way.
    • As I've said elsewhere, I am using the stock intercooler piping path in the engine bay, and a return flow cooler, and making ~250 rwkW (without any effort put into trying to turn it up past there just yet) and expect to be able to make some more, and frankly, I would be perfectly happy with 260-270rwKW. This is peak road Skyline usability territory. You go past there and, sure, the car will snap necks more when it's on boost, but it will also break shit all the time, cost a (even larger) fortune in tyres, etc etc. Anyway, I also do not like the over-the-fan pipe path, and you don't have to do it.
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
    • Not easy to quantify wrt something like how many fractions of a second slower it would be over 0-100. But given that a 250-300rwkW car is able to do that launch sprint in 5-6 sec (and faster with appropriate tyres, and surface)..... giving up as much as a second would feel like torture. A ~450HP capable turbo is not going to make lots of boost in the 2000-3000 rpm range. So, whilst with some boost on hand it will be faster accelerating in that rev range than your engine currently is NA, it will not feel like a fast car until the boost is solidly in. You know what your car feels like right now when you open it up at 2000rpm. if you've ever been in an actual fast car, you will appreciate that the NARB25 is.... not exciting. Well, add some boost and it will be better. But shorten the intake runners and it might not be better at all. It might come out better, but it could end up feeling the same. For me, it's not the 0-X km/h sprints that matter. It is easy to fry the tyres with anything over 200 rwkW. You can't use all the power available in 1st and 2nd anyway, you have to modulate the throttle. What matters is how the car reacts when you're driving in traffic in 4th or 5th and have maybe 2000 rpm on board, and you want/need to add some speed quickly, and don't have time for the downshift. It won't make boost, it will be all NA (at the speeds we're talking about - remember how fast you're going at 2000 in 4th! and don't plan on breaking the limit by too much.) So giving away NA torque is not what I would consider practical for a street car. And retaining that NA torque builds boost faster which makes the car faster. The flashy plenum is not actually better, unless you're looking at a track car where you can keep it on the boil all the time.
    • So how much difference does it make you think? Like 1 second in the 0-100?  I was have smaller turbo so hopefully that spools quick GTX2871.  currently it’s NA so you can imagine pretty slow, but I do want fast accusation a little as there’s not many places I’ll be driving where I go over 80 even near me. So 0-60 and 0-80 targets
    • Short inlet runners cost quite a bit. Dulls off the off-boost torque, and delays boost onset, because arrival of boost is driven by gas flow is a product of the ability to flow air which is torque. This is the reason that the stock manifolds have longer runners. On a 3L, or bigger, you can usually accept the compromise of giving away some torque because the extra capacity gives you a little extra to waste. But on a smaller motor, there's not a lot there to start with. Example, I swapped RB20 out of my R32, 25NeoDET in its place. The "wall of torque" that I experienced afterwards made it all worthwhile. That's because I came from RB20 land where torque is not a thing. But I would not do anything, anything at all, to reduce the low/mid torque I have now, because I remember what it is like to not have it!
