Hi guys.
Selling my 20" wheels and tyres that I bought for my R34 GTR. Would have 90+% tread left. They are obviously 5x114.5 but not 100% sure of the offset. Will find out asap off ozzy tyres. They fit perfectly on R34gtr anyway without needing spacers. Paid $3200 for them (have receipt) selling for $2000 as I have found a set of factory R34 gtr rims to replace them with. One wheel does have a tiny bit of gutter rash but very minor. Will try get pics asap but there is a pic of them on my actual car on ozzytyres.com.au.
https://www.sau.com.au/forums/topic/364074-20-lexani-ls-55-wheels-and-tyres/
Just measured width of wheels with measuring tape and they measure 10 inches wide from edge to edge of rim. I thought they were 20x8.5 but maybe not :-/ also, they tyre size is actually 245/30/z20
Hope that helps
  • 4 weeks later...
  • 4 weeks later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
