Has anyone ever seen an R33 GTS-T with R34 lights on the back?????
I wonder if the tail-light panels are interchangable?
I ask, as I have a seller telling me he has seen plenty of conversions in NZ. A search of this forum failed to come up with any response??
If anyone has done this or at least seen it done let me know. It might give the R33 a strange and unique look.
https://www.sau.com.au/forums/topic/36408-swapping-r33-rear-lights-for-r34/
well i'm seriously considering doing a front end conversion for my 33. I know it'll be ricey and expensive and all, but i rekon it'd be pretty cool to say i own a R33.5 :) oh wells. my 2 cents. but yeh i dont know about the rear lights unless you change the rear quaters as well....
yeh i know, dmd had a 33GTR look like a 34 at last years autosalon. Took out the "thats a sick body kit" award. Was kinda thinking along the same lines except i want to keep the rest of my car. I guess i can sell some of the parts like lights, paneling and front bar to help finance the conversion. Heard the bonnet and lights on the series 2 33's are expensive as all hell.
nah they aint, just they look heaps different. I suppose because there weren't many series 2 cars made. Dont know its only a guess. But i've been told not to hit anything in the front of the series 2 as it can get bloody expensive. 1 headlight alone costs nearly 570 dollars. dont know much about how much the bonnet is.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
