Hey there guys cleaning out the garage so posting up all the items i no longer need please dont hesitate to enquire via PM or text me on 0419761510 cheers!
- R32gtr rear rotor (single) - $20 (slotted)
- R32 gts-t front hard metal brake lines with fittings - $10
- - R32gts-t rb20det OEM turbo charger (blown exhaust wheel) - $30
- R32gts-t rb20det metal cross over pipe (throttle body to I/C pipe) stock with no BOV fitting RARE perfect to run aftermakret bov and look stock - $40
- - r32 gts-t rb20det metal cross over pipe (TB to IC) with stock BOV, 50
- R32gts-t rb20det OEM throttle body - $30
- R32gts-t rb20det coilpack brackets x 2 - $20
- R32gts-t rb20det OEM intake manifold (with everything – valves) - $30
- rb20det turbo fuel pump $50.00
- - r32 full hi-has set up $40.00
- rb20det charcol canister - $10.00
- - R32gts-t rear cradle supports - $20
- R32gts-t gearbox cross-member - $30
- R32gts-t rear tailshaft (centre – diff) x 2 - $20 each
- R33 gts (non-turbo) rear brake callipers and lines - $50
- R33 gts (non-turbo) rear brake rotors (suit 4 stud, set)- $30
- - r33 rb25det brake filler bottle $10.00
- R33gts-t passanger door (painted green) includes power window motors, glass, hinges, door skin $50.00
- r33 quarter pannel indicator (right side) - $10.00
- r33 Smart Entrance box - $5.00
- r33 roof handles $2.00 each x 4
- r33 dash vents <- near windscreen x 2 $5.00 each
- Many Interior plastic panels (enquire for price & availability)
- R33gts-t front passanger sear seats (great conditions includes rails) - $50
- - R33 skyline jack and tool set – $50
R33 boot gas struts - $10
- r33 bonnet release cord - $20.00
- r33 engine bay fuse box and loom - $30.00
- r33 wiper motor- $20.00
- passenger side quarter pannel for an r33 skyline. The pannel is in perfect condition no scratches or dents etc, it is painted green and still has the gt badge and everything - $50.00
https://www.sau.com.au/forums/topic/364192-nissan-skyline-parts-sale-r32-r33/
  • Replies 48
they were on my old r33 and held up my boot with gtr wing reasonably well, from memory one side (LHS) was better than the other, they have been sitting now for about 1 yr so not 100% sure on condition
Hey mate I'm after:
R33 Dash surround + gear shifter surround (manual)
R33 Rear boot trim (This Trim)
R33 steering column plastic surround + the ignition barrel surround/ring (this bit)
R33 Boot lock/badge
R33 Front guard 'GT' badges
Do you have any of these?
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drive beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
