hey guys.
my engine light came on, so i took it to the mechanic and he tested the ecu. he said it came up with faults regard the coil circuit. i just wanted to know what that meant so that i can fix my car straight away. my mechanic didnt tell me anything else part from that. not even the error code.
thanks
https://www.sau.com.au/forums/topic/364413-rb25de-engine-light/
error code 21 will most likely be coil packs, double check that with the mechanic to see if it was the coils, also coils take about 2 hours to change with the parts so you should be good to go in about 1 day. if you have a non turbo like me, you might want to get 1 2nd hand coil pack replaced instead of 6 new iridium ones as that would cost u 600+ instead of about 200 bucks.
i've just rang him and got no reply!!! i just wanted to know what other things would be affected in the coil curcuit for the engine to come on. and yes its a non turbo. if it is the coil packs i was thinking of getting the yellow jackets coil packs? (anyone know if they are good)
cheers
  • 5 weeks later...
could be o2 sensor crank angle sensor or spark plugs, most likely coil packs
Would a faulty o2 sensor cause the engine light to come on?
i took mine (RB25DET NEO) to a mechanic and got the same code result,
He got the same code reply and changed a coil pack he thought was faulty and all the spark plugs.
i still get the problem, the car runs noticeably rougher when the light comes on but usually i can turn the car off and on
again and the light stays off.
The light can go a week or more without coming on and usually tends to come on when i take it easy and drive economically.
Thanks in advance
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
    • lights are on just the one click.
    • Absolutely matters because, while a temperature change will eventually reach a sensor at the end of a static line, the response time is far far far too slow to be useful. Might as well not have a temp gauge at all.
    • When I was eyeing off the 370GT (after deciding I didn't want to spend 30-40k+ to relive my early 20s in an R33) I thought it'd be a good project to add a turbo to it. Now that I have a 370GT, and I've had a couple of chances to open it up, I'm pretty stunned by how much power it makes 🫠 Honestly, the way the VVEL opens it up, it almost feels like there's a little turbo tucked away in there somewhere. It's like Nissan looked at VTEC and said "hold my beer" 😁 Has anyone thrown a turbo into their 370Z or 370GT? Is there a conservative boost level you can run without having to upgrade the fuel system, or are bigger injectors and a bigger pump a given?
