up for sale are parts from my r34gtt neo. i'm selling coz i am upgrading my turbo and other support parts.
  • six R34gtt neo coil packs in good condition $250. done 45000km
  • k&n pod air filter $120. (I will clean and oil with k&n recharge kit before posting) done 8000km
  • pod air filter heat shield $50 (I can respray to cover scratches if you want)
  • *NEW* -8 AN teflon coated stainless steel fuel line (5 meters uncut) $250
  • r34 fuel pump without filter $35. done 45000km
  • r34 fuel pump/cell o-ring $15
  • r34 side intercooler plus pipe and brackets $190. done 45000km
  • r33 side intercooler (small dent, doesn't affect performance) $60
  • r34 stock blow off valve $60. done 45000km
  • *NEW* sard fuel pressure regulator plus turbosmart fuel rail adaptor fitting and tomei oil gauge $200
  • *NEW* 80mm CNC throttle body compatible with nissan TPS $180
  • r34 turbo engine cover plus bracket $70
  • xforce cannon muffler (bolt-on with flange) 3" inlet and 4.5" tip $170. done 8000km
  • *NEW* speedflow aeroquip push hose 400 series -10 AN (50cm) $20
  • blue bumper mesh 70cm x 15cm $10
  • blue bumper mesh 40cm x 30cm $6
  • apexi neo afc $400. done 8000km
muffler and apexi neo afc are still on car, will be removed by friday.
Postage at cost to buyer.
PM if interested
Edited by 369
R34 intercooler SOLD
K&N air filter SOLD
PRICE DROP!!!
  • neo coil packs $200
  • *NEW* K&N pod air filter + HEAT SHIELD $140
  • *NEW* -8 AN teflon coated ss fuel line $50 per meter
  • fuel pump (no filter) + o-ring $30
  • r33 smic with elbow $60
  • blow off valve $40
  • *NEW* sard fpr + turbosmart fuel rail adapter fitting + tomei oil gauge $180
  • *NEW* 80mm throttle body $150
  • r34 turbo engine cover + bracket $50
  • xforce cannon muffler + hanger + gasket (3" inlet and 4.5" tip) $150
  • *NEW* speedflow aeroquip push hose 400 series -10 AN (50cm) $10
  • blue bumper mesh (70cm x 15cm) + (40cm x 30cm) $10
  • apexi neo afc $380
  • r34 afm + plug $80
  • *NEW* GTR r33/34 engine torque damper $70
pick up or post
Edited by 369
more stuff for sale
  • r34gtt neo oil feed line with 2 banjo bolts + 4 washers $10
  • r34gtt neo internal wastgate actuator 7psi $20
  • r34gtt neo air intake pipe $80
post or pickup :)
GTR engine damper SOLD
neo afm + plug SOLD
PRICE DROP!!!
  • *NEW* -8 AN teflon coated ss fuel line $40 per meter
new items for sale
  • *NEW* 3inch silicone hose coupler/reducer $15
  • *NEW* 3inch elbow 90degree silicone hose coupler/reducer $15
Edited by 369
  • 1 month later...
Gizzmo electronic boost controller for sale $210 delivered
comes with the following:
  • boost solenoid
  • gizzmo ms-ibc
  • harness
it has only been used for 6 months at 12psi. still works perfectly! i'm selling it because i upgraded my turbo and put in a high pressure actuator which gives me constant 17psi, hence gizzmo is useless for me to use anymore.
I also have the R34 GTT factory boost controller for sale $40 deilvered
*NEW* R34 GTT Skyline Silicone Hose Engine Bay Dress-up Kit $50 delivered
3 Metres of 3mm Silicone Hose <li>2 Metres of 5mm Silicone Hose <li>1 Metre of 8mm Silicone Hose <li>2 x smaller Jubilee Type Clips (8- 12mm) <li>2 x larger Jubilee Type Clips (12-22mm) <li>2 x smaller T Pieces <li>1 x larger T Piece <li>10 x 100mm Black Cable Ties <li>10 x 100mm Colour Coded Cable Tie
will post pictures asap
Hi flowed R34 Neo top-feed fuel injectors for sale (set of six) $550 delivered
For R34 RB25 Turbo.
The hi flow has been done by PJ's Quick Bits, each injector is 740cc @ 42psi.
Spray pattern is single pencil hole type.
I made 270rwkw with Nistune, etc but wanna upgrade my injectors to 1000cc to run E85, looking for 350rwkw.
I used the injectors for a couple of days since they were hi flowed so they are relatively new.
Here's a list of what's been done by PJ's Quick Bits:
  • Cleaned
  • New filters
  • Flow tested & matched
  • New o-rings, upper and lower
  • New pintle caps
Check out the pics!
PM if interested
Edited by 369
Hose finishers x 16 (doesn't come with clamps ONLY finishers) $10 delivered
  • Fit 6 an (8mm) hose clamps
  • Makes engine bay look neat
*NEW* cooling pro return flow intercooler kit (black) stealth series R34 R33 $510 delivered or pickup $480
Reason selling: i fitted intercooler for dyno tune but it maxed at 260rwkw, fitting a bigger intercooler for 300rwkw+ish.
it is still on my car at the moment but not been used. car is sitting at mechanics workshop waiting for 1000cc injectors and bigger cooler.
will remove it once i get a buyer.
pm if interested
UPDATE... the following items are still for sale
*NEW* 6AN Hose finishers x 16 (doesn't come with clamps ONLY finishers) $10 delivered
*NEW* cooling pro return flow intercooler kit (black) stealth series R34 R33 $500 delivered or pickup $470
*NEW* SARD fuel pressure regulator + fuel rail adapter + tomei gauge $160 delivered
*NEW* 8AN teflon coated stainless steel fuel line (5 meters uncut) $160 delivered
*NEW* K&N performance air filter $120 delivered
*NEW* 80mm throttle body R33/R34 + 3.5" -3" silicone coupler $200 delivered compatible with nissan TPS
*NEW* Apexi pen turbo timer kit $20 delivered
*HI FLOWED & TESTED* R34GTT NEO top-feed fuel injectors (set of six) $550 delivered done by PJ's Quick Bits
APexi NEO Super AFC kit $300 delivered
Gizzmo Electronic boost controller + solenoid $210 delivered
R34GTT factory boost controller $20 delivered
3" Silicone coupler $15 delivered
2.5" Turbosmart silicone coupler $15 delivered
R34GTT turbo oil feed line + bango bolts + copper washers $20 delivered
R34GTT internal waste gate actuator $30 delivered
R34GTT air intake pipe + bov & crankcase recirculation pipes $100 delivered
R34GTT coil packs (set of six) $300 delivered
R34GTT fuel pump (no external filter) + fuel cell o-ring + plug $30 delivered
VAREX 3" cannon muffler 4.5" tip + *NEW* 3" gaskets + bolts & nuts + hanger $200 delivered or pickup $180
R33 side mount intercooler + piping $150 delivered or pickup $120
PM if interested
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
