Some of you are probably already aware that this saturday the EvolutionOz club are having their annual EvoNats at Eastern Creek. Sure the track will be limited to evos but there's a show and shine on and a few other events happening there on the day. A couple other jdm related clubs are planning on coming down and using the event as an excuse to meet up. If you want to check out some cool jap inspired rides or just have nothing much on that day you should head on down for a look.
This was a public service announcement ;)
https://www.sau.com.au/forums/topic/364793-evonats-21-5-11/
it was good. i put some pics in the monthly photo thread already. i'm about to off, i'll post up tomorrow for the lazy ones... the impatient ones can check the photo forum. who knows... u might enjoy it in there ;)
https://www.sau.com.au/forums/topic/364793-evonats-21-5-11/#findComment-5828694
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
