Some of you are probably already aware that this saturday the EvolutionOz club are having their annual EvoNats at Eastern Creek. Sure the track will be limited to evos but there's a show and shine on and a few other events happening there on the day. A couple other jdm related clubs are planning on coming down and using the event as an excuse to meet up. If you want to check out some cool jap inspired rides or just have nothing much on that day you should head on down for a look.
This was a public service announcement ;)
https://www.sau.com.au/forums/topic/364793-evonats-21-5-11/
it was good. i put some pics in the monthly photo thread already. i'm about to off, i'll post up tomorrow for the lazy ones... the impatient ones can check the photo forum. who knows... u might enjoy it in there ;)
https://www.sau.com.au/forums/topic/364793-evonats-21-5-11/#findComment-5828694
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
