HI PPL,
Looking at selling my 1993 Burgundy R33 GTS-t. My reason for selling is i am wanting to upgrade to an R34.
* HKS 3 1/2" exhaust cat back
* Brass button heavy duty clutch
* Iridium spark plugs
* Dash mat and floor mats all round
* After-market steering wheel
* 400R Bodykit (Genuine NISMO Sideskirts)
* Four wheel steering (HICAS)
* Strut brace
* NISMO adjustable suspension
* Tinted windows
* NISMO clear indicators
* Painted dash surround
* Re-trimmed hand brake and gear lever
* Blue glowing speedo and RPM guages (White in Day, Glows Blue with lights on)
* Autometer Phantom series white face Pillar mount guages in dual pod (Boost and Oil pressure)
* Apexi RSM with G-sensor
* HKS Turbo Timer
* Niken Glowing Pedals pedals,
* Under-Body Neons
* Viper Chrome 18" Wheels (original rims with Race tires included)
* Carbon Fibre Bonnet (Original bonnet included)
* HKS air cleaner pod,
* GFB Boost Controller
* GFB Blow-off Valve
* Kenwood touch screen TV/Stereo with CD deck below (Not just TV like cheaper ones, this is a full system controller, i paid nearly $5k when new with the stacker)
* Video CD 10-Stacker in boot
* Kenwood 7x10's in rear parcel shelf
* Kenwood Splits in Front
* 2 x 12" pioneer subwoofers in box (not custom installed)
* Alarm/Imobiliser with Keypad Security
* 5 speed Manual
* Climate control
* Rego till August 04
* KM's 85k
Interior is in very good condition apart from a small cigarette burn on drivers seat (was there when i purchased the car, no smokers ever in car while i have owned it). Paint is very good condition, has had a full re-spray just prior to me buying it.
Looking at $21k complete, i dont really want to start pulling bits and pieces off it just to sell it, the only thing i would probably seperate is the stereo, so probably $19k without stereo.
Car is Located in Perth WA.
Any questions please ask :P
[email protected]
https://www.sau.com.au/forums/topic/36489-perth-r33-gts-t/
  • 1 month later...
Not interested in swap for a modified Onevia by any chance? We both keep each others wheels, you keep most of your stereo gear except for the front/rear speakers and i keep my little Sony deck, you also keep the neons, stickers, pedals and RSM.
http://home.iprimus.com.au/alexbrezo/onevia.htm
If not, disregard this post :)
https://www.sau.com.au/forums/topic/36489-perth-r33-gts-t/#findComment-793026
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
