post-10298-0-19337400-1305955438_thumb.jpgpost-10298-0-96917200-1305955402_thumb.jpgpost-10298-0-85232700-1305955358_thumb.jpgpost-10298-0-01135800-1305955310_thumb.jpgpost-10298-0-83223800-1305955260_thumb.jpgpost-10298-0-34293900-1305955220_thumb.jpgpost-10298-0-72673400-1305955183_thumb.jpgpost-10298-0-48529300-1305955137_thumb.jpgpost-10298-0-14864200-1305955092_thumb.jpgpost-10298-0-78892700-1305955046_thumb.jpgpost-10298-0-52370000-1305955000_thumb.jpgpost-10298-0-86863700-1305954953_thumb.jpgpost-10298-0-75352000-1305954903_thumb.jpgpost-10298-0-93252400-1305954857_thumb.jpgpost-10298-0-80580400-1305954808_thumb.jpgpost-10298-0-48529300-1305955137_thumb.jpgpost-10298-0-14864200-1305955092_thumb.jpgpost-10298-0-78892700-1305955046_thumb.jpgpost-10298-0-52370000-1305955000_thumb.jpgpost-10298-0-86863700-1305954953_thumb.jpgpost-10298-0-75352000-1305954903_thumb.jpgpost-10298-0-93252400-1305954857_thumb.jpgpost-10298-0-80580400-1305954808_thumb.jpgpost-10298-0-20072000-1305954756_thumb.jpgpost-10298-0-07068000-1305954715_thumb.jpgpost-10298-0-30546800-1305954668_thumb.jpgpost-10298-0-54472200-1305954623_thumb.jpgpost-10298-0-62710400-1305954579_thumb.jpgpost-10298-0-82897900-1305954545_thumb.jpgpost-10298-0-39487000-1305954505_thumb.jpgpost-10298-0-14494700-1305954456_thumb.jpgpost-10298-0-70356400-1305954401_thumb.jpgpost-10298-0-27054400-1305954340_thumb.jpg
Guys i have a heap things here that I no longer need. All the stuff to put together a high hp 26/30 "on the cheap" some parts will suit just a 30 or a 26.Preity much every thing needed to build a motor up -just need a decent head gasket and big end bearings and a few other bits.
HKS Pro L stage cams - little use as I went bigger - $800 - bargain, Rb 26 used water pump nothing wrong with it $50,N1 Oil pimp - $100, Custom catch can with internal baffles $50, used set of Scat rods and Ross forged pistons, set of Argo h beams- one new the rest used ,a couple need little end sleave bushed, Cp pistons and rings all Ok except there are a couple of pins missing, rings , New Mahle oversized RB 30 pistons , fly cut for valve releaf , i piston cut wrong - all will make a cheap build on a forged motor $1250, rb 26 sump and diff with new sump baffle $180,044 external bosch fuel pump as new$120,near new over flow bottle with bottom relief $30, Farea in and ex valves ,retainers collets, heavy valve springs $200, RB26 cam buckets a couple of sets,$130, custom billet fuel rail twin entry to suit large injectors , nead a couple of tabs welded on as I cut of to fit 2 side by side, $60,stock R32gtr ECU $50-, HKS cam pulleys $130, RB26 crank$100 RB 30 crank $100 , turbo RB30 block $100, 2 x stagea auto box's- good clutch packs $400 ea, 26 head thats ported properly , has seen 800 hp , has pin hole in #1 and needs welding there and on the rear water jacket- has cam caps to suit $200. Standard 26 engine mounts$30, a couple of Oxy sensors -$40 ea plus other stuff.
Prefer to sell the lot in one go $2k - be quick!
PM me
https://www.sau.com.au/forums/topic/365053-rb2630-parts-or-cheap-build/
PM me
Hi Mate,
Where are you?
Im interested in the lot.
Ha - the only one with any brains so far, I dont really want to break up but people want individual items, fair enough though. Any way , perth WA - w R U?
Even found amulti layer head gasket and a couple of copper ones as well - they will come with the gear, there is a shift light as well, all has to go
Im in Sydney, makes it a bit hard. Good luck
Cam gears, 040 and fuel rail gone.
Rods still on pistons x 2 sets and 1 x set of Argo's and Mahle RB pistons still for sale. HKS Pro L/s are a bargain if youn need big flow.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
