N1 oil pump with 25000 ks on it perfect condition $200
i bought this from japan when i first built my engine, here is my link. http://www.skylinesaustralia.com/forums/topic/172704-money-money-money/
i am selling it as i have a greddy one know.
in sydney
i will post
Edited by WARLORD
https://www.sau.com.au/forums/topic/365546-n1-oil-pump/
Hi Warlord. Dont know much about the N1 oil pump. Will it fit a gtr 34? and does it have any benifits over the OEM unit?
Thanks Ross
i hope this helps
yes it will fit you rb26.as for benifits the n1 has higher pressure than a oem and oem have 12 gears and 81mm and the n1 have 1 less gear and is 77mm
so a bit better than oem
This picture should explain it all... Top is the stock pump, bottom is the N1 pump. Notice the larger volume of the cavities created by the drive gears on the N1 pump (high volume) & the extra bolt hole. Also, the drive gears on the N1 pump are made of much harder steel. That whole bull**** about the two pumps being the same but with different springs is completely WRONG.
https://www.sau.com.au/forums/topic/365546-n1-oil-pump/#findComment-5847522
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
