This Group buy is for SA only.
i am getting some stuff from OS, so i have this group buy which can share a bit of postage for me and SA people can get cheaper stuff. :(
Rear cradle spacer for R32, 33, 34 both GTS & GTR, S13, S14, S15, A31
nomal price: $170
now: $150
cai box for R33, 34 gts & Gts-t only
Nomal price: $190
now: $170
condition : pick up from my place! (5 mins from Marion shopping centre)
end of this GB - 28 March
interest buyer can reply this thread or PM me :wavey:
Very interested, but i have fmic that runs pipe from drivers side into engine bay over fan and connects with original alloy elbow off throttle body. I dont have the original cold air feed because the intercooler pipe passes through its original position. Is it possible that the cold air box could be modified to pick up air from the now empty hole where the factory intercooler pipe once ran? Could this be done for me even if slightly dearer than the buy price.
Do u have an example of the cai box in a car here??
Very interested but i dont have the original cold air feed and also the intercooler pipe goes rite next to the air pod.
So it would be good to see an example first.
Also interested in the rear cradle spacers.
i haven't got it in my car YET (getting mine's though this GB :( ), have seen the real thing, it should be big enough to fit most air filter, at least my HKS and the apexi one in the pic.
car with FMIC should not be any problem as the car in pic also got a fmic.
will confirm about cold air feed.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
