Hey guys,
I know few of us are driving up to deca in the morning. So i decided to organize a meet so we all can cruise up there together.
MAIN WALLAN BP MEET -
Time - 6 15am
Date - Saturday 4th June 2011
Location - Wallan BP 1050 Hume Highway, Wallan, Victoria
Depart - at 6 30 AM SHARP to get there at 8
FOR SE PRE MEET -
Time - 5 15am
Location - Heidelberg safeway, 451 Lower Heidelberg Road, Heidelberg VIC 3084
Depart - at 5 30 AM SHARP to get to Wallan BP by 6 15.
https://www.sau.com.au/forums/topic/366045-deca-pre-meet-sat-morning/
lol...what about Heidelberg safeway for SE pre pre meet on corner of Banksia st and lower heidelberg rd at 5 15- 5 30? if you kewl with that then ill make another thread for SE pre pre meet :P
cant think of another location that will suit SE and East guys...if you have any other ideas for meet let me know :)
Maybe Monash Uni carpark... ...Depends on how you want to get to the meet point... ...I was thinking of going Monash Fwy, Tullamarine Freeway, Western Ring Rd, Hume Hwy... ...But that's just if I was going to be meeting at Monash... ...East Link would also be a way to go from Dandenong...
i usually go monash to bourk then straight up to western ring road to hume...thats why since tht safeway is one the way i thought of that as the meet spot....also i know sanjay lives near that area so itll be eaisier for him instead of coming to monash uni and then back up...this will also make it easier for the guys in the east to meet too...
no point creating another thread for SE the way it looks like...not many people seem to respond to even this main meet...might just orgnaise the SE here and decide and then ill just edit the first post for SE....
So far i got Sanjay and Rhys to the pre meet...hope there are more people cruising up on saturday morning...
That sounds better than my way... ...So I'll meet you there...
Is this the right spot???...
yup..thts the spot...going up north and the safeway car park is on the left...at the intersection....will wait for tommorrow evening and see if others happy with that...then ill confirm it... :)
so you coming with ey...nice...cant wait...
kewl looks like safeway it is then....sanjay dun think itll be open coz vll have to meet there around 5 15 to leave at 5 30 to get to wallan BP at 6 15...but u can either get stuff the nit before or at the BP...:)
Grocery shopping before racing aren't you?
I need two of the big bottles...
Get your own damn Popcorn!
haha... can't wait for DECA!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
