Um........ my 31 has a forged engine with multilayered head gasket To4e, external gate, Nisstune ecu, 440cc injectors, adjust FPR and a whole bunch ov other crap and was all done a Collier engines in adelaide for 6,000 with records..... so thats y everyone seems to question your 5000 to reco an rb20.
A VRS kit cost about 200 bux from motor traders and even with timing tensioner kit proly 500 for both then a few hundred for metal HG and while u doing the Head gasket u can slap in the seals from the vrs kit would take no more than 10 hours of work if u did it slow as f**k and even if u charged $100 per hour lab job would cost no more than 1500 - 2000 for rb20 so please expalin what the other 3000 was spent on so we can ALL understand.
^^ exactly. paying 5 grand to put a metal head gasket and a recod head on an rb20 is f**kin ridiculous
mate no argument its priced well, but when you state things like its had 5000 bux worth of work done,
it rings alarm bells in most peoples heads and makes us wonder IF it really has had that work done why is it so cheap? and it makes no sense 5000 for a head job and new seals on an RB20??
i have a 6000 dollar engine in my car and there would be no way in hell i would get rid of it at 10% of its value,
so im in the same seat as everyone else what has really happened to this engine for it to hav 5000 spent on it and the only upgrade was a head gasket
oh my gosh some people must have never stopped pushing pencils for a second to see what labour costs.
for example. to replace all the exhaust manifold studs on an rb20 with the motor still in the car your looking at close to $1000.
$$$ really do add up quickly.
for exapmle, i ifitted extractors to a triton the other day, it was meant to be a $400 job, by the time the guy left my shop he was up over $1000, when i undid the manifold, every second stud would the thread out of the alloy. so i had to helicoil all the studs and fit new studs.
it may cost $700 in parts to do the work that was done to the rb20 but labour is the killer~!!!
AND THE REASON THE MOTOR IS BEING SOLD IS BECAUSE IM PUTTING A 1JZ IN MY SKYLINE SO I DONT NEED THE RB20. FAAAAARK
Thanks for telling us all about the size of your dick mungy.Would you like to know the specifics of my personal build as well? why doe we need to know about yours in this thread when im selling mine? you obviously have no interest in buying my motor so gtfo of the thread.
how bout ring me up if your genuinely interested,?!?!?!!?
dont have scanner, can read receipts to you over phone and give them to you when you buy it.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
