All parts located in Vic, CBD area - pickup preferred, will post some items at buyers expense.
Email [email protected]
Pics to come.
ATP 'frank' turbo, stainless manifold, t3 flange, will fit s14/15 SR20det, good for around 240-250rwkw with stock cams. Roughly equivalent size to GT30r. Braided lines included. $1300ono
Stack 8130 dash with sensors for oil temp, oil pressure, water temp, $1800 firm > cost over $2200 from vsport australia, excellent condition.
V8 supercar GT wing, 1.6m wide x 12" chord length, comes with mounts and allows adjustable angle of attack up to 20 degrees, painted black, red NISSAN sticker, excellent condition, $1000 for the lot. Will also include black R34 boot lid with pre-mounted reinforced crush tubes to mount the wing for free (will fit R34 GTR or R34 GT-T)
Racepace 3.5" rear muffler, super high flow but quiet $500
will throw in 3.5" cat-back mild steel piping to suit R34 if buyer wants it, i think the muffler can be used on r33 skyline too
used momo steering wheel, center horn button has been shaved around edges but will sit fine bolted to a boss kit, only have 5 out of 6 allen bolts (lost one) $100
used trust shift knob suit r34 skyline, 10mm thread (M10 x 1.25), will also fit s14 200sx, should suit other skylines, very good condition $40
used genuine nismo 1.3 bar radiator cap $20
2 x used genuine hks ssqv blow off valve flange adapters to suit skylines $20 each
r34 gtt triple guages, no housing $40
pair of s15 dmax vented front fenders +30mm brand new $280
Sorry for the delay.. PICS
also added s14 ganador mirrors, electric mirror control via factory loom, blue lens, very good condition. $330
correction the turbo is T2 flange
bit smaller than a gt30... i don't really know the specs it was on my car when i bought it. the induction pipe is included.
oh well, yeah i've had a fair bit of interest in the wing, but mostly interstate! even had a dude in Canada who wanted a shipping quote lol... Not really keen to send it interstate let alone overseas! I'm in no rush either way.
V8 wing in canada. That would be cool.
What model V8 supercar is it off? VY/VZ?
Hey mate spoke to the other day on the phone when you where at re autoworks havnt heard back still waiting to here from you about picking it up
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
