Hi all,
I'm clearing out the shed of some un-wanted gear off my car that has either been changed, upgraded etc. Please note this is my first attempt at selling stuff on SAU, and I work alot, I shall do my best to reply to PM's, texts etc. and arrange freight/pick-up etc as quick as possible, but do be patient.
Best bet/preferred for contact is to PM me on here or text as I can't answer my phone at work.
Contact No: Josh 04 3774 5147
Can freight all items at buyers expense, pick-up is preferred from country south-west vic, exact location will be gladly given to interested buyers but would prefer not to list for security and privacy.
Also happy to deliver items/meet buyer half-way at buyers expense (fuel costs) if distance is reasonable.
Standard parts are off a R33 Series 1 GTS coupe' RB25DE
Fusion EN-AM300200 amplifier, 2 channel, runs 70w rms per channel, suitable for running a pair of 6X9's, is a flow through/daisy chain style amp so another amp can be connected to the same pair RCA leads, bridgeable to run 180w rms, good working order, removed as I went to a bigger system requiring a 4 channel amp. More details here. $30
Sub box built specifically for boot of R33 2 door, sits above the fuel pump area with the battery/fuses re-located, and HICAS ECU mounted to the drivers side, very snug fit. Made from 3/4 MDF with loads of liquid nails and screws, extremely solid, 2 separate compartments, "face-plate" made from 12mm MDF. Average condition, needs the "face plate" re-done/re-trimmed. Had 2 10" subs inverted mount running in it, again has been changed for bigger build, has filler to make the boxes ~14L each, could be removed to go as big as ~25L each. Could be cut out to fit 10" subs normal mount with spacers, too small for 12"s. $30 to good home
post-74990-0-62387700-1307252975_thumb.jpg post-74990-0-85462900-1307253080_thumb.jpg
Stock JECS fuel pump, upgraded, was in running car on removal, but slightly noisy (can be heard on priming and outside the car when running) $15
Two 205/55/R16 91W BCT S600 tyres, changed due to flats pots and worn shoulders, tread varies from %15-%60, suit drifting or burnouts. Not road usable! $50 pair
One Mazda RX8 space-saver spare wheel, 5 stud, off my old car, never used. $50
Standard sway-bars, no links, "D" bushes included $30 pair
Standard springs and shocks, no visible leaks, surface rust, typical condition for age $50 the lot
Genuine Mazda 5w-30 rotary mineral oil, un-opened, paid ~$70 for it yet never got used. $50
Speco-meter 2.5" (I think) electronic oil pressure gauge and sender, good working order, needs wires extended, lights up yellowish standard globe color $20
Random "Nakamichi" CD head unit, has AUX in, came with car, suit daily driver $10
2nd hand oxygen sensor, unknown age, only noticed .5L/100km improvement when changed, suit if you have an absolutely dead one or for testing etc. $20
6 standard coil-packs, acted up on stone cold nights at full load over 4500rpm when car was N/A, taping/greasing may help, suitable for diagnosis or temp-replacement $40
Have a few more small items for sale, but it's raining hard so can't get photos, will update later on.
Cheers, Josh
hey mate do you have a drivers side electric window switch, series 1 ?
Nah mate I don't. Not a full part-out, just some random bits i've changed. smile.gif
Also for sale:
Permatex Ultra-Black sealant, un-opened, un-used. Had my sump off on the weekend, got 2 tubes to be safe, didn't use this one, $15
Another couple items:
Standard R33 GTST intake pipe, no visible damage/splits: $30
Assorted Permaseal gaskets, got the kit for my conversion, only needed the T3 and dump pipe flange ones: $10
  • 1 month later...
  • 3 weeks later...
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
