G'Day guys,
Just wondering who i would be best to see/contact about ordering a rear housing for my HKS GT2530 turbo in Tas?
I am after a T3 V Band .63AR rear housing maybe slightly larger, i currently have a T3 V Band housing on it but it has a 1.06 or larger A/R and is far too laggy on my 20.
Or if someone has one similar to what i want i would swap, this housing would be perfect on a 25 or even a low boost 30 setup.
I have emailed GCG to see if they can help me also.
Any info would be greatly appreciated.
Thanks,
Daniel.
Have just looked up the CHRA number and its actually a Garrett 2860RS, someones put the HKS front housing on and ripped me off lol, this may make it easier to find an externally gated rear housing though.
Ive heard back from GCG today and they will supply me with a T3 externally gated V Band .63 housing which will be here before the weekend, bit exy but im hoping it will be ok, and not too restrictive up top.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
