  • Replies 180
Got a pair of afms(cheers Nak :)) which I will test in the morning and will check the ecu for codes. Short from that, who really is keen for a barby and a few beers and a gtr busy bee tomorrow? Got the day and arvo free as and really wanna get this sorted.
Jesse.
i would check fuel pressure then spark
sounds like fuel pressure
all have to remember the basics of an engine
suck squeez bang and blow
it dosent matter if its a 50 year old push rod motor or a dohc motor its all 4 stroke tec
Any black smoke coming out the exhaust?
I've borrowed wheels for tomorrow to get to the workshop, if I can I will try swing past on the way back. If the mrs lets me borrow the laptop I'll bring that too, PM me your number dude
Thanks all, your all wikidly helpful and willing to help. A far cry from the crx forum or ford wa.. :)
I'm pretty much open to anything at this stage, I just don't have the $ to tell a mechanic to "just fix it". I'm gonna swap in Nak's afms tomorrow and also check my ecu, hopefully that'll answer some questions.
Short from that, I'm thankful for any help I can get with the beastie. :P I'll be home or close by most of the day so anyone who wants to test their patience is welcome to pop by. Haha.
Jesse.
That'd be great Mike, when you have some time(im free most days) I need to swap those parts in to find out exactly what's goin wrong. I also havnt tried your afms coz I dropped my 10mm socket into my engine bay and haunt recovered it yet. :P
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
