hey everyone, in the last week i have finally got the car on the road and been driving it. everything is going good apart from one thing... i will try my best to describe it lol..
kk, so if i roll up to a hill with minimal accelerator and the car comes onto boost on its own (from the load)... say it reaches 3psi or so, well... when i reach the top of the hill and my foot is still in the exact same position. the boost drops off as, and as it does the car starts the "surge"?? i normally change gears or put my foot down but.... if i keep my foot in the same position the blown of valve starts goin crazy, like opens a bit every half a second or so, meanwhile the car surges really bad.... this happens everytime i drive with my foot in the same spot and it comes onto and out of boost by itself... really annoying
any help would be great!!
thanx
edit: forgot the relevant things,, car has
microtech
standard r34 turbos
hks ssqv bov
Edited by BrynDETT
https://www.sau.com.au/forums/topic/366892-standard-turbos-surging/
rly? man that sucks haha... its in a s13 so the engine didn't come with standard ones, is there anyway around it? bov is vent to atmo... would it be better disconnected? hate the sound of it anyways just wanted to make it abit easier on the turbos...
Source some stock ones from a wreckers. But im guessing u have aftermarket cooler piping. Will still work just have to add a piece for the stock ones. They come Bolted to a pipe which is easy to fit. Just make sure you get them bolted onto the pipe when u get them
    • (Rb25det intake manifold) I’m having a hell of a time trying to find the full part or part number of this coolant hardline so far I was given these (Below) but they aren’t what I’m looking for and was told it’s the IAR or aac valve but that doesn’t seem to be it either. If someone could point me in the right direction it’d be greatly appreciated. Or if anyone has it for sale that’d be great too. I have recently purchased a greddy manifold and I can’t seem to find my old one to pull it off.  (Front Heater Return / Water Pipe (under intake): Primary part: 14053‑21U10 (front return pipe assembly for R33/R34 RB25DET) Alternative listing: 14053‑21U00 (same pipe, sometimes interchangeably referenced)   Heater Feed Pipe: Listed as 14075‑04U00 or feed-related variant 14053‑AG500)
    • This sounds cool. But, as per usual, anything really complicated like that, that I take on, constitutes a steep learning curve that I never actually "learn". I just get it working, install it and start using it. Then, when it breaks a few months later, I've got no memory of what I did, how I did it, or even the bloody IP address I gave it. I'm having more or less exactly that problem right now. My Proxmox machine was discovered to be non-responsive, and the VMs on it were ditto. Power cycle it to a stream of loud Dell beep codes - which was unpopular at midnight, I can tell you. Move it to the lounge room so I can HDMI it to the TV for a screen, see the boot messages complaining about the /PVE/data having all sorts of LVM problems, saying it needs to be fixed manually. And I'm like....great. How am I going to work out what I need to do? At least it wasn't the stupid Silicon Power SSD shat itself. Mental note for all readers - DO NOT BUY SP SSDS! They are shit. I have had one take out an entire VM setup already, and this one could have done the same. Maybe it actually has. Cheap Chinesium shitbaskets. I won't cheap out again, even on play projects with no budget. Because my time budget having to fix shit is worth far more than the cost of proper parts.
    • I do typically agree. These days even the screens most people use have more of a boot time than the main device. However, I've seen an interesting use of the RPi in vehicle, however it involves effectively building your own OS and MBR, as then it boots up exceptionally quickly, as you don't have everything needing to start up, and you can then also run it up as an RTOS, while still having more compute than an Android can give for things like display, and processing. A very huge task that would be though for Duncan, I'm not sure that's his skill set (or Arduino programming and wiring) ha ha. If end goal is definitely just water cooling, Arduino would be the simpler setup especially for a rookie. If he wants extra display stuff though, bashing some code in Python on an RPi may be the better result for both systems.   Unfortunately the new device I'm building at work which runs a display, is too slow of a display for dashboard style purposes. More extreme low power, update only a couple of times a day type system
    • I don't like "actual computers" for in car use. They take time to boot up, have OS annoyances, and so on. Arduinos etc are ready to go a few seconds after power on, don't mind being agressively powere cycled, because everything is non-volatile, don't mind being shaken and stirred.
    • As Fred would tell us, it's all about interpreting the rules. It's not a water sprayer, it's a water mister... But everything else you've said, 100%! Even a raspberry Pi would be great, use HDMI out for a display, and add a raspberry Pi CANBus hat to read values out from the ECU.
