Hi guys, I'm only new to this site. I recently purchased an r33 series 2 with the standard double din head unit. I decided to upgrade to a tv/dvd unit. I bought a wiring harness so that I didn't have to chop any wires but after installing I found that the speakers aren't working. The unit itself is coming on and everything is working but no sound. I have checked all fuses and they seem to be fine. My concern is do these speakers have an internal amplifier?
https://www.sau.com.au/forums/topic/367086-speakers-wont-work/
could be unplugged at the speaker, , broken in the door jamb, hacked in somewhere, the external amp not setup to turn on with the radio, no speakers in the holes,
dodgy radio, dodgy plug, dodgy plug install, wrong wires.
did you pop test the speakers during installation ? 1.5 volt battery ??? could be a bad xover .
this is why you pay someone to do it. so you don't encounter a GOTCHA !!!!!.lol my 2c
Sorry. Forgot to mention they work fine with the standard head unit just not with the new one. I am pretty sure it's the wiring from the car to the wiring harness. The standard unit also has a 10 cd stacker in the boot and a separate cable from the stacker to the unit which isn't being used on the new unit. I have looked at the diagram on this site and the 6 pin plug in my car is missing 2 wires and both of them are amp wires. Is this because my speakers aren't amplified or would the wires be in with the stacker wires?
I would suss that problem, don't assume wiring diagrams are right, most are from the USA where skylines were never sold until R35 and the wires still don't match up
most likely a mis wired interface plug. for the wrong car. model. year .
photos would help
do you know if you have aftermarket speakers, like splits ?
Edited by sapphiregraphics
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
