Sorry guys, been flat out with other nonsense.
So far the following things are gone -
* Trim around the steering column
* Turbo
* Power Steering Rack
* Stock coils
* Ignitor
The rest of the car is still there. Plenty of other bits to go!
  • Replies 93
Posted Images
hay mate im keen on the wheels can u please email me at [email protected] or send me a txt or call 0438307579 as im not on here often m in geelong i can head down whenever suits to pick them up but i need to know asap chees mate ,. rick
* Gearbox and related stuff (for a conversion) gone
* Driver's side door gone (just the door itself and window/motor mechanism) - still have door card, electronics, door handle and key
* Turbo
* Stock coils
* Ignitor
Don't forget i've also got the splitfire coils - asking $450. Still have the box they came in!
Hey there mate,
sorry to hear about the accident. I am after two things: I need the LHS passenger air vent and i need the panel in the boot that goes through the rear seats in good condition i hope.
Update - Stuff that's gone so far -
* clutch+gearbox+tailshaft etc for manual conversion (still have flywheel)
* passenger seat belt
* interior mats
* 2x injectors
* Turbo
* Stock coils
* Ignitor
* Driver's side door gone (just the door itself and window/motor mechanism) - still have door card, electronics, door handle, key and mirror
* Passenger side vent
* Headlight switch
* centre console tray holder thing
* fuel pump cradle (pending payment). Still have fuel pump
* front seat buckles (pending payment)
Plenty of car left and those splitfires!
* interior mats
* 2x injectors
* Turbo
* Stock coils
* Ignitor
* Headlight switch
hey mate is that centre console the plastic trim that goes around air-con panel, and shifter? If not I would like it.
