RBSkyline Posted June 12, 2011 Share Posted June 12, 2011 Hey guys, I am stripping my R33 S1 GTS-T ready for track. I have stripped the boot, parcel shelf, rear seats and unbloted the seatbelts no im am alittle stuck as to how the rear side trims all come off... I don't want to break anything so is there a trick to it at all because I cannot see screws or clips... Any help would be much appreciated. Link to comment https://www.sau.com.au/forums/topic/367483-stripping-interior-tips/ Share on other sites More sharing options...
Craved Posted June 12, 2011 Share Posted June 12, 2011 gets a bit tricky as the front seat belts go through the side rear trims. there is a screw in the small pocket where the belt runs through the panel, thats the only one per side - so unbolt that screw and the main bolts for the upper belt and then just pop the clips on the panel like you would on the door trims Link to comment https://www.sau.com.au/forums/topic/367483-stripping-interior-tips/#findComment-5861813 Share on other sites More sharing options...
RBSkyline Posted June 12, 2011 Author Share Posted June 12, 2011 I have unbolted to seat belts as they are coming out also. So i have to find that screw first..... and clips you say.... so i have to give the panels a good pull? do i take the top part off first or the bottom panel off first (near the bottom of the rear seat?) Link to comment https://www.sau.com.au/forums/topic/367483-stripping-interior-tips/#findComment-5861831 Share on other sites More sharing options...
Craved Posted June 12, 2011 Share Posted June 12, 2011 bottom panel first yep, just pull on the panels as close to the clips as possible screw should be obvious behind the seat belt as it passes through the panel Link to comment https://www.sau.com.au/forums/topic/367483-stripping-interior-tips/#findComment-5861839 Share on other sites More sharing options...
RBSkyline Posted June 12, 2011 Author Share Posted June 12, 2011 Ok mate I will give it ago, please check in on this topic I will post updates Link to comment https://www.sau.com.au/forums/topic/367483-stripping-interior-tips/#findComment-5861861 Share on other sites More sharing options...
