hi all. i have a heap of bits for sale. located in launceston Tas.
i have a nardi leather steering wheel. black leather. VG condition. no centre cap. with D1spec removable boss. $250 ono
Whiteline front springs to suit R32 gtst. same as SK group buy springs. $50
Whiteline sway bar links, brand new. $140
R32 GTR rear sway bar. very light. grate upgrade for gtst skyline or S13 $120
Pair of 16x6 work rims with nexen tyres. $100
Stock gtst front bar $100
Gtst rear seat. imaculate condition. later model fabric. no fading. $100
Gtst rear seat. earlier fabric. faded and average condition $40
gtst 4 door front seats. in tweed. ok condition. could do with a clean. $100
2 3/4" exhaust to suit gtst. $100
Pivot engine start button. has been installed. comes in original box with instructions. $80
also have an aftermarket fiberglass front bar. i brought off daniel H. cant rember what i paid but its here.
feel free to offer on anything on here.
pics on request
https://www.sau.com.au/forums/topic/367778-shed-clear-out/
  • 2 months later...
what stud pattern are the 17x8 work rims? pics? how much
exhaust is just mild steel. but muffler is stainless. open to resinable offer. it looks like this.
wheels are 5 stud nissan and look like this minus red stripe.
they are perfect fit for stock gtst front guards. and are 3 pice.
looking for $250 or ill just keep them.
they can be pulled apart and painted/ polished like this if your keen like i was once.
Edited by DJRIFT
https://www.sau.com.au/forums/topic/367778-shed-clear-out/#findComment-6006682
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
