What date suits you best...
22 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 127
Here are the pics , if you want a full size of any pic, PM me your email and which one(s) you would like and I'll send them your way.
Also i have started a FB page -Stageas - South Australia, feel free to join and see how things go from there.
Edited by bentwagon
Was the first Stagea cruise we've been on. Weren't able to stay for the lunch but look forward to the next one! Thanks Mark & Jules for organising it.
We took a few pics at first meeting point and attached to link below.
http://s81.photobucket.com/albums/j209/stocky_tg/Stagea%20Cruise/
I rocked up to lecornu's @ 10:25am, guess you guys left early?
So sorry you missed us all :( ...on the 11th July the start time was changed to 10am
Yes we did leave at 10am....hope you can join us next time
O'Mark
Awesome cruise Mark and Jules, thought it didn't end the way I had planned!
After leaving you guys I thought I'd take advantage of the fog, get a few pics and have a half hour power nap, so found a dirt road (something all good cruises have) and took a few snaps then positioned myself so I could join the convoy as you went past.
Forgot I had my lights on didn't I!!:whistling: And my foggies and my stereo and just about everything else, so needless to say she was dead.
After an hour of waiting for some guy to get back with a jump I thought f@#$ it and rang the RAA so they could make me $250 poorer!
Moral of the story? Get some sleep before going on a cruise.
This is what i got for my $250 post-78650-0-58090100-1310954521_thumb.jpg + some others
Thank you for your kind words & thoughts re: the photo shoot !
Sorry it ended up such a nightmare...not sure that pic is worth $250
OLD Jules & me
The cruise was great as was lunch. Big thanks to the Olds for organising it, Dotti and I had an awesome time and cant wait for the next one :thumbsup:
Few pics Dotti took http://www.facebook.com/media/set/?set=a.1989826340084.2108096.1076100613
