OK, so there is no classics for sale section that i can find, and i thought seeing as though this place has some of the most hardcore DR30 nuts in Aus i'd offer the stuff up for you guys!
I have a built FJ20 with rods, forgies, ported head. Brand new fibreglass DR30 bonnet. DR30 oil cooler kit with remote mount filter and full braided lines. Doors, door windows, dash, R30 cluster, boot lid, R30 head lights amd tail lights and heaps of other random bits. So if your looking for something, hit me up.
https://www.sau.com.au/forums/topic/368653-dr30-stuff/
  • 4 weeks later...
  • 5 months later...
Hi
I am interested in body parts around the firewall. Could you let me know where you are and if that area of the car is available or do you want to sell the whole shell? What condition is it in?
Regards
John
https://www.sau.com.au/forums/topic/368653-dr30-stuff/#findComment-6249225
  • 3 weeks later...
  • 2 months later...
  • 1 month later...
  • 1 month later...
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
