hey guys ive got a brand new Garrett 35/40 twin scroll .84 turbo for sale it was built for me by hypergear, haven't even bolted it to my manifold
turbo in brand new a/r 70 front housing .84 twin scroll t3 flange 4 bolt rear looking to swap for a garrett 3076 external gate .82 plus some cash my way depending on turbo
THIS TURBO IS EXTERNAL GATE AND BRAND NEW
or cash $1300 ono
TURBO IS IN PERFECT CONDITION BRAND NEW NEVER USED WOULD JUST PREFER A 3076 FOR MY NEW MOTOR AS I ONLY WANT 320RWKW OUT OF MY RB30DET CHEERS
https://www.sau.com.au/forums/topic/368856-brand-new-garrett-3540-twin-scroll/
yeah genuine garrett ball bearing and its a custom made turbo from hypergear no numbers on turbine housing as im not to sure how many people are aware but the .84 twin scrolls are widely available and sorry not selling it that cheap i only put a price for forum rules i want to swap but if it was for cashe would need to be 1300
TURBO WAS BUILT BY HYPERGEAR 2 WEEKS AGO RECIEPT WILL BE PROVIDED COMES WITH 12 MONTH WARRANTY
REALLY ONLY LOOKING TO SWAP FOR A 3076
$1300 JUST INCASE THE FORUMS NEED ME TO PUT A PRICE UP
Also the normal atr45 bush bearing internal wastegate .82 rear housings of hypergear staos make around 320rwkw on 18/20psi now giving this is external gate ball bearing and twinscroll rear will
Expect 350rwkw out of ur rb25/rb30s or even rb30det quiet responsively
Anyone?
I'm not really needing this just get as I'm still running with a pair of HKS GT-SS and waiting to see what my dyno results are after the rebuilt motor which I'm about to run in has its final tune..... If you would do something better on price I could be swayed.
Let me know if $1100 inc postage to Brisbane would get the deal done. 0402 101 939
come on guys this is extremely cheap ive seen second hand 35/40s sell for more then this as this is brand new and also twin scroll it will spool up pretty quickly on a rb25det anyone interested
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
