Hey guys,
i've got a set of Volk Rays GT-C Gold which are 19x8.5 +39 (will fit GTR offset was on a R32 before my evo7), they are in pretty good condition. They come with brand new Federal 595 EVO tyres which are 245/35R19 that are filled with nitrogen and have been balanced. They are pretty light considering 19's (2 piece forged rims).
selling for $2200 (not willing to seperate centre caps, no trades, no swaps).
if you want the rims you will have to organise your on transport (courier), but pickup is welcome (im located in canberra).
pm me or contact me on 0401573850
cheers
https://www.sau.com.au/forums/topic/368943-fs-volk-rays-gtc-gold-19x85-39/
Agreed, very good price. Hell if I could sell mine to some one I'd buy these off of you. *txts friends to buy wheels*
Have you got any photos of them fitted on the EVO or the GTR?
thats when it was on my evo however they dont do it any justice...
sorry no pics of it on a GTR but it was on a R32 before i purchased them.
the centre caps are near new, as i've only trial fitted them. didnt commit to puttin them on as i read this post saying that someone got theres stolen hence why they look brand new.
Edited by Icey_Cold
  • 3 weeks later...
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
