Hey all,
I have changed my mind and decided to sell my R33 instead of replacing the engine.
It's a 1993 R33 GTS series 1 with a suspeced spun bottom end bearing
asking 5K neg
ENGINE/DRIVELINE/ETC
  • Factory manual
  • Heavy duty clutch
  • Catback exaust with 3" cannon exaust
  • Engine oil & oil filter changed every 7,500 km
  • Gear box oil just changed
  • Brakes fluid just changed (inc bleading of all lines all the way through)
  • Recently changed radiator fluid
  • 18*,***kms (mostly highway, I live in Whyalla)
  • King Lowered Springs
  • KYB shock (less then 10,000kms old)
EXTERIOR
  • Full viva garage type 2 bodykit (light damage to front bar, nothing structural to the car)
  • 25mm flared guards front and rear
  • re-spray in blaze blue (outside and door jams only)
  • Xennon lights (low beam)
  • stock rims with near new tyres, can arrange for some 17" ROH rims to come with sale
INTERIOR
  • Very good condition, besides wear on right side of drivers seat and wear on handbrake "grip"
  • Genuine skyline floor mats (all 5)
  • Average sound system; 4" JBL parcel shelf, clarion cd player
  • Momo steering wheel with boss kit
  • Isotta shifter
  • Climate Control globes replaced with white 40,000MCD LED's (very bright white light)
  • Ignition light also replaced with 40,000MCD LED
THE BAD
Knocking noise from engine, 90% sure its a big end bearing. has not been driven since the noise started
slight power steering leak, one of the seals in the pump is on it's way out
flat battery, car has been sitting there for a couple of months
This car would either be great for someone as a first car or someone on their p's, although a new engine or a bottom end rebuild will be required.
Also would make a good shell if you have written off your R33 and just need to transplant parts.
Or just make some cash and either replace the engine or part it out
I'm interested in keeping the following parts (price will be reduced accordingly)
Gearbox
cat-back exhaust
The car is currently located in Whyalla SA, but can transport to adelaide
Best bet would be to text me on 0407971706
Cheers Luke
Photo's will be up by 2moro
Edited by 2FST4U.R33
https://www.sau.com.au/forums/topic/369903-r33-for-sale-sa/
Not sure how much it will cost didn't get it priced as no one in whyalla (country town) wanted to touch it, if could do all the work yourself it would cost a few hundred bucks in parts
seeing as a low km rb25de long motor can be found for well under $1000 can't see the point in using a 180,000km+ engine, plus it would be heaps easier to replace then repair.
Pretty keen to get rid of it seeing as i just bought a new turbo and few other bits and peices for the 180, so give us a reasonable offer and it's yours
https://www.sau.com.au/forums/topic/369903-r33-for-sale-sa/#findComment-6016531
you would have to upgrade the brakes as well (i think it's only the fronts from memory) front calipers and disks are normally around $300 or so
https://www.sau.com.au/forums/topic/369903-r33-for-sale-sa/#findComment-6023383
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
