oh well,
if u can't beat 'em, join them!
i reckon it would look great if we arranged a meet for all r33's near sunnybank, QLD to share the secrets of stealth. looks dun matter, it's the inside that counts...
https://www.sau.com.au/forums/topic/36991-wicked-rides/#findComment-738949
...i hate it when you pull a car length and a half on someone and they pull up next to you and say "...i've only got an exhaust, running on stock boost mate..."
so farken wot! you still got owned and a car length is quite a shitload especially only through 1st, 2nd and maybe abit of 3rd...
https://www.sau.com.au/forums/topic/36991-wicked-rides/#findComment-739002
sleepers...........wolf in sheepskin. i heard my mates who are a lot more knowledgeable about cars talk about what they think is the ultimate sleeper. apparently there is this type of toyota work van that can have the Soarer engin fitted to it, cant remember if its the V8 or twin turbo 6. but either way its an upgrade from the 4 it has in it!!!!! anyone know what this is??
lots of people say that they like sleepers, but there are very few around, most skylines have cosmetic mods.
https://www.sau.com.au/forums/topic/36991-wicked-rides/#findComment-740868
I went to trade school with a guy who had a sigma with a valiant 360 in it, still registered as a 4.
A friend i used to surf with back in the day had a crap, rusty rx4 with faded paint but with a $5000 13b turbo engine in it. The look on peoples faces when they got utterly destroyed by that car was gold. Especially other rotory potatos.
https://www.sau.com.au/forums/topic/36991-wicked-rides/#findComment-741231
last night>
4 guys in V6 VS commocrap (with bodykit and rims for extra power) driving along next to me wind down their window and say "next lights mate"
Me: what about them
Tools: wanna race?
Me: who?
Tools: us!
Me: not really
I was almost tempted to educate them... but... I am a good boy now;)
https://www.sau.com.au/forums/topic/36991-wicked-rides/#findComment-741839
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
