so the foot brake works like normale, just takes the long way around though the hand brake.
And that works with no other problems.
The car I drove with hydro HB the foot pedal would drop when you go on the HB, never actaully needed both at the same time though so it was OK whistling.gif
https://www.sau.com.au/forums/topic/369957-hydro-handbrake/#findComment-5897919
Any drop in the foot brake with using the Hand brake ?
Isn't that what I just said?
When you use the HB, the pedal would drop.
I'm not sure if all setups do this or if it was just this dodgy brothers one.
I use the stock HB in my drifter, works fine.
https://www.sau.com.au/forums/topic/369957-hydro-handbrake/#findComment-5897963
This can happen. The typical setup isn't ideal, as the hyd steering stick interrupts the normal rear brake circuit. Not really a problem as plenty of rally cars have it set up like this. If you're worried about it, a more elegant (although slightly heavier) solution is to mount a second pair of small calipers onto your rear brakes, plumbed into a completely separate circuit. It adds a little weight (specially unsprung) but keeps the brake circuit intact, and there's less chance of bias issues etc.
https://www.sau.com.au/forums/topic/369957-hydro-handbrake/#findComment-5898017
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
