so the foot brake works like normale, just takes the long way around though the hand brake.
And that works with no other problems.
The car I drove with hydro HB the foot pedal would drop when you go on the HB, never actaully needed both at the same time though so it was OK whistling.gif
https://www.sau.com.au/forums/topic/369957-hydro-handbrake/#findComment-5897919
Any drop in the foot brake with using the Hand brake ?
Isn't that what I just said?
When you use the HB, the pedal would drop.
I'm not sure if all setups do this or if it was just this dodgy brothers one.
I use the stock HB in my drifter, works fine.
https://www.sau.com.au/forums/topic/369957-hydro-handbrake/#findComment-5897963
This can happen. The typical setup isn't ideal, as the hyd steering stick interrupts the normal rear brake circuit. Not really a problem as plenty of rally cars have it set up like this. If you're worried about it, a more elegant (although slightly heavier) solution is to mount a second pair of small calipers onto your rear brakes, plumbed into a completely separate circuit. It adds a little weight (specially unsprung) but keeps the brake circuit intact, and there's less chance of bias issues etc.
https://www.sau.com.au/forums/topic/369957-hydro-handbrake/#findComment-5898017
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
