Ok so i can get the hose kits through my local dealer that is willing to source them from japan, rough estimate of $500-$600. if anyone is interested in getting a full engine/heater/radiator hose kit. let me know any ill get back to u with an exact price.
Yeah dont get china spec no-name silicon hoses - they're not reliable... IIRC BeerBaron mentioned Samco do quality silicon, or just get the Nissan OEM rubber ones.
JC that seems quite expensive (but since Jap made should be good quality). IIRC OEM from Nissan cost me somewhere around the $300 mark.
i'll second that, genuine nissan, brand new, no problems.
I have been hearing too many problems arising with silicone hoses of late. Also if they are under the plenum and you have a problem, they are not exactly a nice job to change, do it onece and properly.
my 2 c
whats wrong with the chinese silicon ones? theres some on ebay for like $170 from asi_performance (or similar). They're actually in Laverton not far from my work.. Anyway interested to know what issues u guys have had/heard of.. considering im like halfway through replacing all my old ones with the generic silicon hose kit.. gotta be better than the old rubbish thats in there atm surely..
I had ebay (non-branded) silicon radiator hoses. Always leaked, and one failed after about a year. Went back to OEM and they're perfect.
Actually I have their number... 0393695712
Melbourne branch of these ppl - ASI Performance - http://www.ebay.com.au/itm/Nissan-R32-GTS-RB20-RB25-silicone-radiator-hose-BLACK-/290578650137?pt=Motors_Car_Truck_Parts_Accessories&hash=item43a7d65419
From memory it was something like 4 Weddel Ct Laverton, just an office/warehouse in an industrial area really.
I actually went in there and picked up my hose kit a cpl months ago and he had heaps (at the time). I actually spoke to him on Friday about a kit for an RB20DE for a friend and he said he only had top/bottom hoses in stock. The kit (which excludes those) is $170 pickup but 1-2 week wait.
I was told it would be $600 to replace my hoses from Nissan.. pfft, plus something like $80-100 for either the top/bottom hose I forget which.. either way I'll just swap them again.. if I still have the car at that point..
I do see your point about the hoses underneath tho. My car is in pieces tonight.. more hoses splitting.. And I saw one short hose that runs from a pipe out of the block (joins to bottom hose) and into like.. well the top of the oil filter..ish (haha very technical).. anyway NFI how you're supposed to get that off lol.. was like wtf :huh:
I should take a photo, just makes no sense to me..
@Kaz180
Yer mate i know ur point about them being heaps cheaper and all, obviously they dont have the whole engine hose kits on ebay as the one u posted is just the radiator hoses. As it stands the chinese silicone hoses have too many bad reports for me to go that way. So if anyone is interested i will see if i can get a better price for a group buy, i will most likely be ordering in mid to late august.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
