White 96' R33 GTST, immaculate condition in and out no dents or scratches!
96,500km's
Manual
Turbosmart dual stage boost controller (hi-lo)
APEXi S-AFC II air fuel controller
Full HKS Superdragger exhaust, 3.5" mandrel bent with high flow cat
Blitz BOV
Heavy Duty Brass Button Clutch
Hicas 4WS
HKS Type 0 turbo timer, displays volts etc.
Autometer Boost guage mounted on A pillar
Dual Stage shift light
Nismo Gear Knob
HKS Pod Filter
Short Shift Kit
Strut brace front and rear
Racing Pedals
Red VHT sprayed Calipers
Series II Bodykit
Koni height and damper adjustable suspension with King Spring low's
17" BSA Racing rims 235/45's all round, brand new Dunlop Leman's tyres on front
Full central locking and 3 point imobiliser alarm
Dual airbags
Hicas 4 wheel steer and ABS brakes
Receipts for many of the above mod's, Lots of money spent!
Can be included, competition stereo. Pioneer double facing head unit ($1400), 220W Pionner front splits with tweeters and 300W 6X9's in Rear. Speakers powered by a 480w pioneer amp. Two 12" SPL Competition square kicker subs in box in boot powered by a 1000W Crossfire amp and crossfire sub control switch mounted under stearing column. setup worth $5000 legitimately can provide model numbers of every component if you would like to check.
Extra's: Tommy Kaira Wing sprayed same colour as car, White faced colour changing EL dials and blue axs seat covers.
$24,900 ono contact via email [email protected] or pm me.
im in noosa about 2 hours drive from gold coast....if your genuinely interested pm or email me and we can talk further.
Add me to MSN mate. I got a bruz in Dickie beach, mate. My bruz said its about half an hour or so to Noosa. He said he can check out da car man.
[email protected]
[email protected]
thanks for the interest JOSH......you have far to much spare time on your hands :D
anyway...car is still fs, so come on people
looking at 24,900 with sound system, its genuinley worth around 6000 installed. If your interested pm or email me and we can talk further. The plates will most likely sold with the car, until its sold im going to keep them.
Car is still available, I thought it was sold today however it fell through. Anyone interested feel free to pm or email me. Cheers Matt
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
