The following SAU t-shirts (pictured above) are available for sale:
  • Watch this space...
Sizing information can be found here.
Priced to clear: $25.00 for the standard t-shirts or $30.00 for the long sleeve option. Prices include postage within Australia. International shipping is available at a surcharge. Pick-up available within South Australia (for those of you who know me / would like to meet me).
Payment accepted via EFT (direct deposit) or in the form of a cheque or an Australia Post money order. Cash accepted on pick-up.
To purchase: Post your e-mail address and the item you're after below. First come, first served. All buyers will be contacted via e-mail.
SAU t-shirts are not available to order currently - so get in fast.
Any questions? Post below or e-mail [email protected].
Edit: To answer a frequently asked question: Christian (Prank) is in discussions with Nissan Australia regarding approval for further SAU merchandise. Assuming there aren't any problems, hooded jumpers, female fit t-shirts, polo t-shirts and a larger range of standard and long-sleeve t-shirts will be available to order very soon. Keep an eye out.
https://www.sau.com.au/forums/topic/37023-sau-t-shirts-discounted-to-clear/
  • 1 x S white. SOLD.
  • 1 x S red. SOLD.
  • 1 x L white (long sleeve). SOLD.
  • 1 x L blue.
  • 1 x XL white.
  • 1 x XL black.
Will there be more in the future??
The above t-shirts are left over from past orders. They are discounted to clear.
