The following SAU t-shirts (pictured above) are available for sale:
  • Watch this space...
Sizing information can be found here.
Priced to clear: $25.00 for the standard t-shirts or $30.00 for the long sleeve option. Prices include postage within Australia. International shipping is available at a surcharge. Pick-up available within South Australia (for those of you who know me / would like to meet me).
Payment accepted via EFT (direct deposit) or in the form of a cheque or an Australia Post money order. Cash accepted on pick-up.
To purchase: Post your e-mail address and the item you're after below. First come, first served. All buyers will be contacted via e-mail.
SAU t-shirts are not available to order currently - so get in fast.
Any questions? Post below or e-mail [email protected].
Edit: To answer a frequently asked question: Christian (Prank) is in discussions with Nissan Australia regarding approval for further SAU merchandise. Assuming there aren't any problems, hooded jumpers, female fit t-shirts, polo t-shirts and a larger range of standard and long-sleeve t-shirts will be available to order very soon. Keep an eye out.
https://www.sau.com.au/forums/topic/37023-sau-t-shirts-discounted-to-clear/
  • 1 x S white. SOLD.
  • 1 x S red. SOLD.
  • 1 x L white (long sleeve). SOLD.
  • 1 x L blue.
  • 1 x XL white.
  • 1 x XL black.
Will there be more in the future??
The above t-shirts are left over from past orders. They are discounted to clear.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
