im currently converting my whole front end to S13 silvia at the moment. it's a lot of mucking around! note: you can also use silvia brake upgrades then too.
ive almost finished the conversion. just need to put some more money into it. when it is done ill be writing up how to do it. no point telling you right now as i dont know how to finish it just yet.
Depends what you want to use the car for.
As a std restoration
For the cost of buying used parts that may well be as tired as what you have now I would invest in replacement strut cartridges and then replace any balljoints and bushes as required
As R34 says, fixing the stock front end is by far less expensive than going down the modifying track.
A set of springs will cost between $200 ~ 300.00, no matter wether they are King's or custom made and the replacement strut inserts, the sky's the limit. You might find a/mkt Ultima inserts fairly cheap on fleebay but they wont control the new springs unless made to factory spec. A Monroe GT130/GAS replacement is a cheap upgrade from stock, adjustable Koni's would be my recommendation but cost is the element then.
It all depends on your budget and the purpose you want the vehicle for?
Cheers, D
I am using off-the-shelf Pedders red springs over koni red adjustable shocks, with magna ventilated disk and hilux calipers. Pedders (polyurethrathanesomething) bushes throughout. These are all bolt on modifications only. The car (also a 78 C210) stops and corners really well.
I would never knock the S13 conversion, I'm just way too lazy to go down that path, and have no welding/fabricating skills to speak of anyway.
ive fitted modified hr31 front struts, had the smaller c210/r30 spring platforms fitted as the r31 springs r massive... these bolt to stock c210/r30 steering arm, have floating hub and 100mm caliper spacing same as s13 so makes for good upgrades, shorter tube than original so at a lowered height will have more travel, wide range of inserts easily available bilstein/koni etcetc, and still use standard fitment springs and tops. hubs can also be redrilled to 5stud easily if u want to go that way.
if this interests you ill have 2 sets of these modified hr31 complete struts forsale soon as im going coilovers in both cars.
jon.
Actually, a mate of mine in Tasmania bought eBay USA coilovers for 240z, he checked with them and they assured him they'd fit his C210 coupe (not sure how they'd know given the lack of C210's in the states). Anyway, I'll try and get an update about how they worked out.
As far as I know there are a bunch of similarities between 240z's and C210 Skylines; I'm using the Hilux caliper over Magna ventilated disks up front, and a complete 280zx diff cradle and disk brake rear end on my C210.
At a guess the original Toico disk and drum set up on the C210 is the same as the 240z...
Zed front struts are different to everything... they are shorter (have the spring seat welded further down the strut tube) and use a smaller spring, and different strut top, and different strut insert...
240K/200B struts are the same (and I think the same as C210)... and brakes about the same or smaller than C210 (I think smaller)...
R30/R31 are about the same size brakes, but different bolt pattern... and as above R31 struts use very big springs... you can use R30 struts and custom springs, to lower them back to standard height but the strut insert is not in the middle of it's travel so firmer on the bump, and softer on the rebound...
Early 180B struts will let you bolt a commodore caliper straight up, used with machined Audi front rotors used to be the mod to do... now everyone goes to S13 brakes for early Datos...
Cheers,
Daewoo
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
