  • Replies 64
Lowthy - your in with Ash
Keiran - I've made the adjustment, Jett and his missus now have their own room
Chris Taylor - as per your message to me yesterday, Ive added your booking in
The Hotel is now FULL
Jason - unfortunately I have been unable to book you a room. You could contact the Tudor Motor Inn, they are a 2 minute walk from our hotel. Let me know if you would like their number.
I think theres something wrong with your web site link ha? :domokun:
Is it suppose to be:
www.tiranamotorinn.websyte.com.au/ ?
OK.... its on again and I have booked us the hotel in Shepp for the upcoming DECA.
When: Fri 26 & Sat 27 August
Where: Tirana Motor Inn
Address: 33 -37 Wyndham St, Shepparton
Website: (if you wanna have a look) http://www.tiranamot...websyte.com.au/
Cost: $50 per person per night (if sharing)
$85 per night to have a single person in a room by themselves
If you would like a room, please let me know as soon as possible, they will want to release to the public whatever rooms we are not using in a few weeks.
I need to know:
* nights staying
* how many people
* what bed configurations you need (ie twin, double etc)
If you are coming by yourself, that's fine, just let me know and I will team you up with somebody else to share a room with.
Let me know here, by email, by PM or by phone.
The sooner you tell me, the easier you make it for me.
*** NOTE - if the hotel books out, preference will be given to those staying both nights
- if you ask for a room and don't turn up without letting me know, you get added to my black list (you ppl are starting to ruin it for everyone)
Entries coming soon
DINNER
Dinner has been booked again at Taco Bills with Baz, Chris & Kylie running the night again.
If you are staying Saturday night at the hotel, I will book you a seat at dinner. If anyone else stays in Shepp, but not with us, let me know so I can add you to our booking.
Add to Dinner:
Jason
Ay Russ - no spare beds.
The 6 of you are in the rooms with a double and 2 singles (15/16).
Convince 2 of the guys to share the double and your good though :D
Ok. If anyone has a spare bed for my mate Ross that would be cool. Please let me know. He's cool. Doesn't smell too much lol
Hey Bec I'm coming to visit!!
OK..you twisted my arm I'll stay as well for the Saturday night!
But don't worry about accomodation, I'll work my own out, please add me to the dinner list though!?
I'll be rocking up late morning so if you need volunteers in the afternoon sessions I'm happy to help?
Cheers,
Shane
hey bec
Its kool Rus can take the spare room you guys have...would hate it if i woke some of yous up with my exhaust on sunday morning as i gotta head of early for a shift back in melbourne.
but i'll still attend dinner n chill with the group on sat night.
cheers.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
