Bahaha was anybody just listening to Nova??
"Doing burnouts in your stock skyline" got my attention, so I searched and found this so I could hear it all...
If you haven't heard it yet here it is
http://www.novafm.com.au/audio_fitzy-wippa-s-song-parodies-jar-of-hoons_102262
Nothing special, and no point to this thread, just a quiet Thursday afternoon share
cheers!
https://www.sau.com.au/forums/topic/370940-jar-of-hoons/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
