hi guys, tax time is looming and im using my cash to shiny up my R32 gts-t, just wondering if anyone knows any reliable shops that do full window rubbers for front and rear windscreens and driver and passenger seals/dress strips,
any referals would be greatly apreciated.
Cheers,
Ralf "Mumslayer" Birkmann
https://www.sau.com.au/forums/topic/371039-r32-window-rubbersseals/
We use 'Windscreens for Cars'
They can remove and refit the screens and they can source the aftermarket seals. I would definitely go Nissan genuine for seals though as the aftermarket ones never do the job properly.
Also expect to have the front screen smashed when if it's removed. I suppose it all depends on whether you even need to remove them or if you're just replacing the very outer
how patient are you? it takes a LOT of time to cut the thing out and clean the channel. the back has a bit more 'give' in it when you release it. the front will break if you pull too hard. it is hard to explain unless you do it.
