Dba Rotor & Intima Sr Pad Group Buy Excellent Prices!
DBA & IMTIMA PAD GB 20/7/11 till 25/8/11 (or till ten spots filled)
Ok guys this is it DBA and intima pad group buy is up you can buy just the pad's or just the rotors if you want them both combine the price for the pad and the rotors togeather off the price list i have put up if you want them for a different model or car etc PM and post and i will get quote's for you be patient though :) all prices include delivery to your door!!!!
Other rotors 5000 series standard and standard intima pads avalible at request post and PM and be patient please
Supplier is Carbling and is a local business owner looking out for us guys http://www.carbling.com.au/
DBA rotor information
Motorsport and premium street performance
6X6 WIPER-SLOT Vehicle
Body Style Driving
Conditions Braking
Style 4000_wiper.jpg Sedans
Wagons
Coupes
Pickups
Convertibles
Minivans/Vans
4WD'sStreet Driving
City Traffic Driving
Country Driving
Off-Road
Motorsport
RallyNormal-Hard
Heavy Load/Towing
Racing features_4000.jpgDBA's mid-series enhanced performance rotor features Thermal Stability Profiling for improved heat handling and Thermo-Graphic paint markings for effective heat monitoring.
The unique 6x6 Wiper Slot is designed to efficiently clear the gases, dust and debris, resulting in a cleaner disc surface for better braking while maintaining maximum friction.
4000 series rotors also incorporate the innovative Kangaroo Paw ventilation design, which runs cooler, stronger and outperforms traditional straight vane disc rotors by up to 20%
Designed for the performance street and motorsport enthusiast
Premium quality braking for normal street use
XS Vehicle
Body Style Driving
Conditions Braking
Style 4000_XS.jpg Sedans
Wagons
Coupes
Pickups
Convertibles
Minivans/Vans
4WD'sStreet Driving
Country DrivingNormal
Normal-Hardfeatures_4000.jpg4000_web_XS_comp.jpg DBA's mid-series enhanced performance rotor features Thermal Stability Profiling for improved heat handling and Thermo-Graphic paint markings for effective heat monitoring.
The unique 'XS' pattern is a premium (advanced) cross-drilled and slotted pattern, providing improved braking performance for street use only.
Intima SR-6300 Series Brake Pad
Application:
Performance Street, Circuit Race & Drift Track Use (Low Dust & Hi Temp 700°c)
Description:
Intima's range of SR-6300 brake pads provide stable braking through the entire temperature range and have superior fade resistance. These pads are for the driver who wants confident braking on the street and on the track. The SR-6300 brake pad provides this confidence by having excellent braking capability up to 700°c. These pads also have a very low dust output and a 100% non Asbestos organic (NAO) formula.
Specifications:
Heat Range:
Effective Braking 50°c - 700°c
Average µ:
0.4~0.5
AMECA CERT CDGE CODE: TBT SR63T GG
100% NAO Formula
Recommended for use with slotted rotors
Pricing list (includes delivery to your door!!)
word doc.docx
ok guys fill and place orders away :)
1.
2.
3.
4.
5.
6.
7.
8.
9.
10......................................
Edited by BLITZ-26
You might want to talk to GSL Rallysport.
For my M35 they've quoted me $410 for DBA 4000 slotted fronts (pair) as their normal price, so assuming your non-Brembo discs would be about the same, I'd say if the pricing was sharper for the group buy you might get a better uptake?
Guest
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
